ICP Sensor - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-06-2012, 10:06 AM Thread Starter
ICP Sensor
My truck randomly would not start one day after work so after some research I unplugged what I believe to be the ICP sensor on the right side valve cover. Tried to fire it up and nothing happened. Once I plugged it back in, she fired right up. Before I purchase a new one, is there anything else I should take into consideration as far as the truck not starting. Once I plugged the ICP sensor back in and drove it home it sat for about two weeks. I went to start it up the other day and now when it starts, it starts off with a big single lope or bellow if you will, then returns to normal idle. The check engine light is now on but I'm sure I just triggered that by unplugging the ICP.
Let me know what you guys think.
Thanks.
2004 F-250 4x4 sc long bed
afe intake
mbrp exhaust
SpeedyLube202 is offline
post #2 of 6 Old 07-06-2012, 10:20 AM Thread Starter
......and would this be an ok replacement?
Ford Powerstroke Diesel Power Stroke ICP Sensor & Plug OEM 6.0L VT365 2004-2009 | eBay
afe intake
mbrp exhaust
post #3 of 6 Old 07-06-2012, 01:09 PM Thread Starter
afe intake
mbrp exhaust
post #4 of 6 Old 06-02-2013, 02:37 PM
rockbound's Avatar
need one too was looking at this same thing for my 03..
any ideas if this is ok?
03 6.0 crew cab short bed, powermax, edge evolution monitoring sct tuned running srl, cold air intake, egr delete, straight piped, rotella t5, and elc.
rockbound is offline
post #5 of 6 Old 06-02-2013, 02:52 PM
Sinister Diesel Sucks!!!
michaelaiman's Avatar
Quoted: 251 Post(s)
I would stick with OEM on that particular sensor. Just my .02
03 F350 SD 6.0 PSD FX4 XLT CC LB SRW FOR SALE!!
To see why you should avoid Sinister Diesel, visit these threads:
michaelaiman is offline
post #6 of 6 Old 06-02-2013, 03:26 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 449 Post(s)
Garage
I agree OEM is well worth the extra money because the part is very important and must be dependable. Look online for a OEM ICP also make sure the pigtail is free of any oil or corrosion. The ICP is a variable resistance pressure sensor that regulates the HEUI systems injector pressures and they are constantly in flux depending on speed load rpm etc. One pin with corrosion will cause a issue with resistive values being sent to the pcm, if pigtail has any flaws replace it too.
Go OEM IMHO................
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
