Is my Turbo Blown Video?
It was a very hot day in Ohio around 100 degrees. I was making a lot of stops and turning the engine off with out letting the the turbo cool down first. I was completely forgetting how hot the day was and did not let the oil flow through the turbo before shut down. Then while I was driving it I got into the throttle and all of a sudden it started loosing power, then started making a leaf blower sound or more like a blown up vacuum cleaner noise. I immediately pulled over and poped the hood to check for blown off CAC connections. I did not find any obvious problems. I then started the truck again and it still was making the noise when reved up (no noise at idle). I then drove the truck for about a block to check to see if it could build boost and it wouldn't build a single pound. I knew something was majorly wrong so I had it towed home from there. Also no major amounts of smoke. No smoke at idle and just a little bit in bursts when I was driving it down the block to check for boost. I read usually blown turbos dumb loads of blue smoke. Thats not happening. Today I took off the air box and got a look down the turbo. All the fins look and feel fine. The compressor side spins freely and has no resistance. Feels normal to me. I started the truck for a brief second to take this video. Any ideas before I just start tearing it down?
http://s1227.photobucket.com/albums/...t=78a05939.mp4 Also heres what done to the 05 6.0L: 5" MBRP Straight Pipe Turbo Back SCT Tuner with Looney Tune 6.4 Banjo Bolts New Oil Cooler less than 1000 miles ago. Cleaned Turbo by me less than 1000 miles ago. No Gauges yet but will be getting some soon. Last edited by wwholden; 07-06-2012 at 08:59 AM. |
Anyone????
why in the world are you running that with no air filter that is a awful idea
Mind I ask if you replaced the seals of the turbo when you cleaned it?
It was only ran without the filter for the duration of the video. It was in a clean environment so I don't think it harmed it any. I wanted it off so I could see if the compressor side of the turbo was spinning.
Seals? I don't remember there being any seals in the turbo when I cleaned it. I bought the ford cleaning kit and followed its instructions. I did replace the gaskets that the oil tubes connect to. The one up top and the o ring down bottom if that's what your talking about.
Anyone have any idea on what's causing this sound?
Do you have a monitor? Have you checked the vgt sensor and plug? Do you have any dtc's? I don't think you trashed your turbo just because you jumped in your truck and took off.
Sent from my SCH-I500 |
Ok, checked out the vid, bad boot or exhaust flex joint. Common. Imo.
