6.0 injectors leaking down weep hole - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-04-2012, 06:50 PM Thread Starter
I have a 6.0 early 03 with 206k I am having injector leak down and last oil report I had fuel in the oil. I have replaced all injector o rings and I also tested with uv dye. I replaced a injector for a extreme leak what looked to be out of the weep hole. I am still leaking down over a 24 hr time span, has anyone else had an injector fail by leaking out of the weep hole?
TRouth302 is offline
post #2 of 5 Old 07-05-2012, 03:29 PM
southend's Avatar
Where the heck is the injector weep hole?
Sent from my SCH-I500
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #3 of 5 Old 07-05-2012, 03:30 PM
Gotta agree never seen a weep hole on any injector I have ever pulled.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #4 of 5 Old 07-05-2012, 08:15 PM Thread Starter
It's there. Call alliant power and talk to the tech about it. Older c94 injectors can scar and then leak out of vent / weep hole under ledger on the hold down on the injector. It is there so it does not get air locked when oil fires the plunger. His words not mine.
post #5 of 5 Old 07-05-2012, 11:02 PM
Well I try to learn sumthin new every day an I jest learned sumthin
