Parts List For Semi-Bullet Proofing Project
I need some help! A couple weeks ago I posted an issue with my 6.0 overheating while towing. I picked up a ScanGauge II over the weekend and was able to get some more accurate EOT and ECT readings. Yesterday while cruising at about 70 mph on the freeway the EOT was running about 208 while the ECT was around 191. It was in the high 90s outside, AC was going and there was nothing being towed/hauled. This leads me to think I have a restricted Oil and/or EGR cooler? I think we have decided to tear into the engine and start a semi-bulletproofing project but I need help determining what parts to replace and what is needed to do the job CORRECTLY. I have about a dozen pages bookmarked with part lists and they all seem to be different. The build date on my truck is February, 2003 and it has 175,000 miles. I already have a coolant filter installed and have had it for about a year.
Would this be a good time tackle a head gasket/stud job? Should I also replace the EGR valve at the same time? What other gaskets/seals should be replaced at this time? Replace T-Stat? Replace Water Pump? Here is the partial parts list I have compiled so far, any suggestions/additions would be appreciated! New EGR COOLER from Bullet Proof Diesel New Oil Cooler: 3C3Z-6A642-CA Intake Gasket Kit: 3C3Z-9433-AA Turbo Reconditioning Kit: 4C4Z-9V424-AA (depending on what it looks like) New Turbo oil supply line and turbo oil drain line - I've seen that these were different on the 03's. Is there any way to tell what I have or if it needs to be replaced? Degas Bottle Cap: RS-527 HFCM Drain Plug: 6E7Z-9C082-A Fuel Filter Kit: FD-4616 |
Oil cooler and EGR cooler service PDF files and notes The turbo oil supply line could potentially be different. Check the connection at the oil cooler cover. If you see what appears to be a large nut on the oil supply line, you would have to purchase the whole oil cooler cover for a newer truck to be able to change over to the newest style turbo oil supply line (the oil cooler covers were only changed once, so any other year will work if you choose to go the route of replacing the cover). This info is also in that "sticky" If you need to, yes. If you don't, no. If you need to, yes. If you don't, no. Quote:
Thermostat change is a good idea..and you should be performing a full cooling system flush PREVIOUS to undertaking the oil cooler/EGR cooler replacement. I recommend taking that opportunity to change over to a CAT EC-1 rated coolant. Waterpump? Only if your having problems with it. Quote:
![]() How can I tell if I need a new EGR valve? I haven't installed once since I've owned it. I tried to remove it once to inspect it but was unable to get it out. No coolant loss so I'm guessing we can just do the Oil and EGR Coolers for now. Quote:
![]() Thanks for your help! |
Here is a trick for popping that valve out of there. Remove the two small bolts holding in place. Firmly grasp the EGR valve and twist it so that the tabs are accessible. Use a good length of tie wire (2-3 feet long) and feed one end of the tie-wire through one hole in a tab and the other end oif the tie-wire through the other hole. Twist the tie-wire ends upon themselves, forming a loop above the valve. Using a rake or shovel or broom, insert the handle through the loop and use the alternator for leverage. It will pop right out of the intake. CLICK HERE for directions on how to clean it. Quote:
I have attached the FORD TSB for Diesel Coolant Maintenance that you should read. It details how you are supposed to maintain it, which not many do. Your oil cooler has become plugged by the junk that forms due to neglect of the Ford Gold Coolant. Coolant filters will help, but it will not cure the problem. Flush it out of your engine and be rid of that beast. I went to the local International Truck dealership and bought the coolant they use (Fleetrite ELC). NAPA also sells a Zerex ELC that meets the CAT EC-1 designation. Make sure the coolant you use meets that designation, and not all of the ELC's out there do. (ELC=Extended Life Coolant) Quote:
The issue with the "old" lines is that a slight restriction can form in the interior of the flexible stainless steel portion. I believe that the replacement covers are a little on the pricey side, but am not completely sure about that. Give Tousley Ford a call and ask them for pricing. They used to sell the oil cooler and the oil cooler cover together as a "kit" but I believe that kit has been discontinued. The oil supply and drain lines would be separate purchases as well. These two lines will run you about 100 bucks. Last edited by NYC F-350; 07-04-2012 at 04:56 PM. |
Don't leave straight distilled water in the cooling system any longer than you need to.
Rust scale can begin to form rather quickly and that would defeat the purpose of flushing the cooling system in the first place. I would use the VC-9 cleaner at a minimum to clear any rust scale that is in your cooling system now. Did you get the PM I sent you? |
