Should I have the valves adjusted after machining heads? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-04-2012, 12:23 AM Thread Starter
RoCkfiSh363's Avatar
I am about to fill my 2005 up with oil and start this thing for the first time since I fixed my gaskets and studs and oil cooler ect. My question is... should I have gotten my valves adjusted, I had the machinist take .005 off of them but didn't have valve work. Also, do I need to put the balancer in six oclock position?
05 EX Cab Short
8 inch Fabtech
38 inch SSRs on 17x10 Centerlines(powdercoated)
SCT Innovative tunes
Banks CAI
Offroad MBRP Stainless 4.5 " and up pipe.
Auto Meter EGT, Fuel pressure, Trans Temp, Oil temp, water temp gauges.
Blue spring , bored 3 hole banjos.
ARP Studs
OEM Ford gaskets.
EGR Delete, cooler delete.
Bulletproof stand pipes
AMP Power Steps
Kicker Audio
Yukon 4.56 gears
Innovative 48v FICM Performance flash.
RoCkfiSh363 is offline
post #2 of 9 Old 07-04-2012, 01:52 AM
Valves should be fine at .005". Putting the dowel at the 6 o'clock position is for assembling the heads, so hopefully you did that. I like to turn it over a few times by hand after assembly before doing a powered crank with the starter.
2012 F-150 XLT Ecoboost SuperCrew 6.5' 4x4
cartmanea is offline
post #3 of 9 Old 07-04-2012, 02:24 AM Thread Starter
Dangit. I left the balancer where it was at for the whole job. I put the pushrods and rockers all in the exact orientation as they came out and oiled them up really good. If I turn the motor a few times by hand should I be okay??
05 EX Cab Short
8 inch Fabtech
Banks CAI
ARP Studs
OEM Ford gaskets.
AMP Power Steps
Kicker Audio
Yukon 4.56 gears
post #4 of 9 Old 07-04-2012, 07:46 AM
Can't say for sure, but definitely turn it over by hand first and stop at the 6 o'clock position.
post #5 of 9 Old 07-05-2012, 02:10 PM
powerstrokecrzy's Avatar
Quoted: 241 Post(s)
Bump for ya. I wanna know for sure also.
Sent from my DROID X2 using AutoGuide.Com Free App
05 250. Lariet. 4x4.
arp studs w/oem gaskets & all updates
Warren 175cc/stock sticks
Egr delete
Zoodad
New oil cooler
Coolant filter w/ zerex ec-1(homemade)
4" turbo back, straight piped
SCT livewire (running TSD SPD)
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Ccv reroute (dump to atmosphere)
Air Horn Kit
high idle
Pro comp "bullet hole style" 17" w/ 35" nitto trail grapplers
powerstrokecrzy is offline
post #6 of 9 Old 07-05-2012, 04:09 PM Thread Starter
WEll I started to crank it with the key and no bad noises, seems to be rolling over smooth. My problem is.... it will not fire. I've let the fuel prime and prime and charging batts. Does it take an extrreme amount of cranking before it will start? Also, I think my driver side batt is pretty weak. Any thoughts?
05 EX Cab Short
8 inch Fabtech
Banks CAI
ARP Studs
OEM Ford gaskets.
AMP Power Steps
Kicker Audio
Yukon 4.56 gears
post #7 of 9 Old 07-05-2012, 07:52 PM
It will take alot of cranking to prime the hpop system back up. theres alot of air in there with you having everything apart.
curitis9 is offline
post #8 of 9 Old 07-05-2012, 09:06 PM
Yeah, just keep cranking for 10-15 seconds at a time, allowing a minute or so for the starter to cool off in between. Might take several of these long cranks before it will fire. Watch your oil pressure gauge, your HPOP system won't really start filling until you see that finally come up and it takes a while. On the 3rd cranking session on mine after 10 seconds or so the oil pressure came up and then it fired a second or two later.
post #9 of 9 Old 07-05-2012, 09:13 PM
Quoted: 28 Post(s)
Your Injector Control Pressure(ICP) wont start the engine/allow it to run if the pressure is lower than 500PSI. Like others said the HPOP needs to get the air cycled out of it...
06 350 CCLB
Edge CTS
Up-Pipes by Cutting Edge
ARP's
Bulletproof EGR Cooler
Coolant filter
rentstdi is offline
