6.0L Crank no start when warm - Ford Powerstroke Diesel Forum
Old 07-03-2012, 04:35 PM
I have an early (March) 2003 6.0L that won't start once its warm. I checked out the ICP sensor and harness (which were replaced 2 years ago) and they were soaked with oil. Unplugged the ICP, still no start. I threw some money at the problem and changed the IPR valve, still no start. I plan to change the ICP sensor since it's obviously leaking oil, but could that leak be sufficient enough to lose pressure to the point that I get a no start condition? Or should I plan on tearing something else apart?
Also, not pulling any codes. Runs great when if i start it when cold, getting plenty of fuel in the bowl, fuel filters are new, FICM is good.
Old 07-03-2012, 05:57 PM
Has it had updated stand pipes and dummy plugs? A bad o-ring on one of these can cause your problem.
Old 07-03-2012, 06:10 PM
It was my understanding that the 2003's do not have dummy plugs. But I could be wrong. Haven't really looked.
Old 07-04-2012, 12:55 PM
I know the 03s do have some "early engine only" parts. I was just throwing out some generic 6.0 info. Sorry.
Sent from my DROID X2 using AutoGuide.Com Free App
Old 07-05-2012, 01:23 PM
You obviously have a hpop leak imho, classic symtoms. You may need to do the hpop leak test. sorry i'm not sure how thats done, google it.
Sent from my SCH-I500
Old 07-05-2012, 01:42 PM
MAD - Modification Addict
Feedback Score: 7 reviews
You definitely need to have a HPO system leak down test done. You have to get a fitting that will screw into the hole where the icp sensor goes and with the truck off you pump around 10-15 psi of compressed air into the HPO system and listen to where the leaks come from. It sounds primitive but its the only way to get all the leaks out.
Once you fix one leak put it all back together and test it again to find other leaks.
Wash, rinse, repeat.
Edit; I had to do the same thing on mine and ended up having to replace my HPOP, IPR valve, Stand Pipes, STC Fitting, Dummy Plugs, Oil Fill tube, CCV, new intake gaskets, new oil cooler screen, thats all I can think of off the top of my head. What I'm trying to tell you is be prepared to spend some money. I had over $1000 in parts when I did mine. lol and that was just to get her running again. Now I'm getting ready to stud it and rip it all back down for a 3rd time.
Old 07-06-2012, 10:23 AM
I was afraid that's where i was headed. Thanks for the info. Any idea what size fitting i need to plug in to the hole for the ICP? And how to I get the IPR closed?
Thanks again everyone.
