No start hot start - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-29-2012, 06:54 AM Thread Starter
BCF250's Avatar
No start hot start
Ok guys I think my IPR is hanging up and just want to make sure with some of you guy that are a little more experienced. First off, its a 2006 f250. I just had the FICM repaired by Ed at ficmrepaire.com. So after driving the truck for most of the day yesterday starting and stopping the engine, I go to start it and all it does is spin over. No start no try to start nothing. I tried unpluging the ICP sensor to see if it was that. Nope. I let it sit for about an hour and try to start it again. First try nothing but before the second try I didnt turn the key completly off and then she start. I get it home and put the AE on it.
with engine off
IPR volts .23
IPR % 14.54
ICP PSI 3-5psi
FICM volts 48.5
Main power 12.5
FICM synced
I watched everything as i tried starting and it started no problem
at idle
IPR volts .84
IPR % 22.6
ICP 581psi
FICM 48.5 v
Now today I tried to start it when it was cold and it wouldnt start. I watched the IPR % go from 14.54 to 84.33 while cranking. Everything else was the same except only getting about 350 psi on ICP. Im thinking the IPR is hanging open and not alowing it to build oil pressure to fire the injectors?
What do you guys think?
Sorry for the long post
BCF250 is offline
post #2 of 3 Old 06-29-2012, 02:44 PM
rdunagan's Avatar
ive got a truck in here doing the same thing. only builds 300 psi on icp but it only does it hot. i think the branch tubes have a crack in them. to me sounds like ipr is fine. thats what mine was doing also but when hot. it would start out at 22 and then jump to 84 while cranking to try and build pressure i guess
2009 Ford F-350 FX4 4x4, H&S 300HD, MBRP 5" DP back exhaust, S&B intake, sinister egr delete, 4" BDS lift with fox shocks, 20x12 fuel nutz, 37" toyos, Custom painted headlights by me
SOLD: 2006 Ford F-350 4x4 King Ranch,ARP Head Studs and all the works
rdunagan is offline
post #3 of 3 Old 06-29-2012, 04:31 PM
mechanix's Avatar
When the IPR goes to 88% it is trying to close to build pressure because the ICP is not seeing a high enough pressure like it wants to see. I would suspect a leak in the high pressure oil system, dummy plugs, stand off tubes etc...
Eric
03 F350 Super Duty
ARP head studs
Warren 155/30% injectors
Barder Stage 2 turbo
SCT Tuner
EGR delete
35x12.50x20 Nitto Trail Grapplers
mechanix is offline
