P2285 Code only - Ford Powerstroke Diesel Forum
Old 06-22-2012, 12:02 PM
P2285 Code only
'04 6.0L. Truck was idling, hesitated like it was going to shut off and idled back up then just shut off. Started truck back up and check DTC and pulled P2285 drove truck home and ran fine.
Old 06-22-2012, 12:20 PM
Take a look here to see what it means:
http://www.dieseltalk.com/support/DTC.pdf
Old 06-22-2012, 03:46 PM
T T T
Old 06-22-2012, 04:03 PM
Send a message via AIM to Fantom
Looks like you need to replace the ICP sensor and connector
Old 06-22-2012, 04:48 PM
Could the IPR also have anything to do with it?
Old 06-22-2012, 05:42 PM
When mine had a P2285, had to replace the leaking ICP sensor, then it was fixed. Later replaced the pigtail, I would recommend doing both.
Old 06-24-2012, 05:53 PM
T. T. T
Old 06-24-2012, 05:59 PM
Replacing the ICP didn't help?
Old 06-24-2012, 06:19 PM
Didn't get one yet was seeing if there were other thoughts
Old 06-24-2012, 07:49 PM
Check your blinker fluid.
