3 weeks old, now "low oil pressure" light?! - Ford Powerstroke Diesel Forum
Old 06-22-2012, 03:10 AM
Hello everyone-
So I bought a 2006 crew cab king ranch from the local dealership about 3 weeks ago. now when I start it up i get a "low oil pressure" warning. It will go away if i blip the throttle. It happens throughout the day when I am at idle.
I have a 3 month warranty from the dealer. What should I hope they replace? Low oil pressure pump? HPOP? I just want to be able to talk to the service manager and have expectations ahead of time.
Thanks!
Old 06-22-2012, 03:58 AM
possible STC fitting, standpipes, dummy plugs, or ICP sensor. Although i am told late 06 early 07 builds have the updated stc,standpipes, and dummy plugs from the factory.
Originally Posted by diamondplate View Post
Hello everyone-
Thanks!
Old 06-22-2012, 04:13 AM
How will I know if I have the updated standpipes, and dummy plugs?
Old 06-22-2012, 04:23 AM
Ummm, check the oil first.
Old 06-22-2012, 05:37 AM
I think that warning is based on too low of pressure from the low pressure oil pump. As previously stated, check your oil level.
Possible causes are bad low pressure pump, obstructed pickup, bad pressure regulator, bad oil, low oil. Could aslo be a bad pressure sensor.
Considering you just bought it and is is not leaking vast amounts of oil, the dealer should correct any of these issues. However, if it is just low oil it would save you a bunch of time to just check it yourself.
If you are feeling ambitious, you could tee in a manual pressure gauge and observe the actual pressure.
MikeB
Old 06-22-2012, 10:27 AM
I checked the oil level and it looks right on.
Old 06-22-2012, 12:02 PM
Thank you everyone for your thoughts!
I did notice that it takes a little more cranking for it to start. not sure if I am imagining it or not.
Old 06-22-2012, 04:13 PM
You need to get something to monitor your low pressure oil and high pressure oil to see what the deal is.
Old 06-22-2012, 04:46 PM
sounds like it could be LPOP
Old 06-22-2012, 07:25 PM
Powerstroke Techie
Has this truck had a recent set of EGR/oil coolers replaced by any chance? If so, it wouldn't surprise me if the oil pressure switch has failed. At the very least, it would be a very simple and inexpensive part to "try" as a start. Replacement only requires the turbo oil supply tube be removed to access and replace.
