big lag at stop going to wot - Ford Powerstroke Diesel Forum
post #1 of 34 Old 06-20-2012, 06:19 PM Thread Starter
i have a 2005 ford 6.0 ccsb and when i take off from a dead stop, say a stop light or stop sign it lags very bad with hardly no power for roughly 3 seconds then runs like a bat outta hell. i have just done the blue spring upgrade myself last weekend and did not see any problems with installing it. i changed the oil with rotella 5w40 T6 with revx oil additive. i changed both fuel filters while running revx fuel additive. i have k & n intake, 5 inch turbo back exhaust, and a custom tune from vivian (looney tune which is a very badass tune). the only thing i can think at this point is to check FICM voltage and/or clean turbo. any ideas would be helpful!.
waterfowl1989 is offline
post #2 of 34 Old 06-21-2012, 05:46 PM Thread Starter
Angry big lag at stop going to wot
post #3 of 34 Old 06-21-2012, 06:26 PM
ebusa's Avatar
If you mash it without any boost built up it will get lag until it boost up. Does it do this from a 5-10 mph roll?
-Evan
Semper Fi
2005 F350 Crew Cab LB FX4 Lariat
Loaded-Leather, Sunroof, 06 Chrome Package
5'' Tuff Country Lift
Toyo MT's 35's with Race Line Renegade 20's
ARP Studs, EGR Cooler Delete, Coolant Filter
MBRP 4'' Exhaust Turbo back, No Cat
SCT X3 Tuned by TSD & IDP
Stock Airbox, NON-MAF Truck
GT3788VA POWERMAX Turbo
DiProcol Optix EGT & Boost Guages , Scangauge II
ebusa is offline
post #4 of 34 Old 06-21-2012, 06:34 PM
Making ported intakes
ODAWG714's Avatar
Quoted: 6 Post(s)
It's. Probably that 5in exhaust it need more back pressure
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
post #5 of 34 Old 06-21-2012, 06:42 PM
strokemyego's Avatar
i'd agree. i'd say your turbo either needs to be reconditioned or its a combo of the 5 in exhaust and the intake
strokemyego is offline
post #6 of 34 Old 06-21-2012, 06:43 PM
Enterko's Avatar
Not trying to be a jerk by any means but this isn't true. Plenty of people run 5" exhaust. BP in the exhaust is really only needed on gas vehicles to help enhance savaging. Remember that there is a turbo in between the manifold and tail pipe.
To the OP. Is this something that has happened all of the sudden, or since you have been tuned?
2005 F-350 4x4 SRW CC LB
ARP Head Studs, EGR Delete, Insight CTS, 03' Turbo
4" MBRP Turbo back, SCT SF3, 6.4l banjo bolts
Leveled, 36" SS Irok's, 20" Moto Metal MO950
Enterko is offline
post #7 of 34 Old 06-21-2012, 06:52 PM
kingranch89's Avatar
sounds very normal for a 6.0 to me i would not worry about it
2007 F250 king ranch 6.0 powerstroke
SCT w/ custom tunes from innovative
5" mbrp exhaust
Studded and EGR Deleted
FINALLY SOLD!!!!
on to the next toy
kingranch89 is offline
post #8 of 34 Old 06-21-2012, 06:57 PM
Enterko's Avatar
I agree...
Enterko is offline
post #9 of 34 Old 06-21-2012, 07:01 PM Thread Starter
it will usually lag until i hit about 3-5 mph then it takes off. i have had this problem since i got the truck in march. i have tried a couple different tunes with no help to the lagging problem. i am going to be changing the intake to an s & b soon. i am wondering how would i be able to put more BP in exhaust? just to see if that fixes the problem
post #10 of 34 Old 06-21-2012, 07:04 PM
ODAWG714's Avatar
Quoted: 6 Post(s)
Not to be a jerk either but on my truck and friends trucks removal of muffler creates less back pressure n more lag and from my tuners they say the same thing. He will need his tune fixed for his loss in exhaust argue it all you want
Oliver
ODAWG714 is offline
