Another Dreaded Newb - Ford Powerstroke Diesel Forum
Old 06-19-2012, 06:13 AM
Yes I know, newbies are a pain but just remember, pain is part of life - or so I think. - and speaking of pain... Just bought a 2005 F-250 Powerstroke, my firstest diesel ever, has 122K on it and other than it's black and it came from Florida, I know very little else about it.
After some haggling with the dealer, I drove my new toy home and decided that I'd better do the general maintance on it given the fact that I don't have the truck's service records. Leaving the store with 4 gallons of oil, two transmission filters, and gas filters I left feeling a bit violated.
Changed the oil and solved the "WTF" puzzle with the oil filter, the previous person used some off brand which left a plastic piece still in the cap. Once I removed that, the motorcraft filter went in nicely and the truck ran fine.
Then the gas filters went in. I "probably" would have been ok except the oil filter issue made me wonder, "What other surprises are in store for me with the previous owner's choice of filters". The small gas filter ( on top of the motor ) did not again look exactly like the motorcraft filter I was installing and then I started thinking and here things went South.
I looked at the teal o-ring looking ring at the top of the post that is part of the truck's gas filter and wondered if that was part of the OLD gas filter that I just removed. When I removed the old oil filter, part of it was left behind so I wondered if that belonged on there or not. I installed the new filter without bothering it, changed the other filter in the frame and started the truck after 4 cycles and it idled fine.
A couple days later I was going to take the truck and a mile from my house it died. It began running like crap, shaking and hammering hard and then the motor died. My mind flashed back to that teal ring in the gas filter area and I assumed that my mistake was NOT removing it, so I took it apart and removed it breaking it in the process ( Just the little ring ). I started the truck, it idled fine for 5 minutes and I thought all was well and it died again in about a mile.
Some checking on the net revealed that indeed the teal ring I removed was meant to be there and wasn't to be removed. I have ordered the part from my Ford Dealer ( $42 ) and will install it again.
My question is: What does that little teal ring do anyway? I believe that even after I install this new part back into the gas filter canister that the truck will again do the same thing... idle fine for an indefinate amount of time but shut off in a mile or so. I must say this first taste of a diesel truck isn't very sweet.
Thanks to all who read all of this and don't send hate mail. LOL
Ken
Old 06-20-2012, 02:40 PM
I dont know about the ring you are talking about, but I must say that you may need to replace the old oil cap with a motorcraft cap if you are not sure what it is now, and maybe both fuel filter caps. The ford oil cap is shorter than some others, and should be verified.
Sent from my SCH-I500
Old 06-20-2012, 04:39 PM
That teal o-ring that sits on the black tube is to seal your filter. Without it, you may have fuel pass by that is not filtered. The fuel is introduced into that fuel filter housing through the black stand pipe. The o-ring seals around the inside of the fuel filter and the fuel rises into the inner portion of the filter. Then the fuel runs through the filter to the exterior part of the filter and rises into the bowl. From there it is distributed into 4 (I believe its four) different fuel lines. A couple going to the heads, I think one is a return, and cant remember what the other is for without going out to the truck to look. Hope this info helps.
