Injector Codes, but Running Fine
2003 F-350 w/128k miles.
So a couple months ago I did the ECR delete, coolant filter, and turbo line swap. Everything went reasonably okay, and the truck has been running fine since. But last week I got a P0272 code pop up, and today I got a P0263 code as well. Nothing else though, and the truck is running fine. Have I blown some O-Rings, or is my HPOP going bad and losing pressure? I find it too coincidental that two injectors would fail so close to each other, on the same side of the engine. Anyone have any ideas? Thanks George |
i'm assuming the oil cooler was done too? clear the codes and see if they come back. may have set when you were burping the oil.
Yes, you're right. I also did the oil cooler. I've tried clearing the codes a couple times, but I'll try again. Thanks.
System is still throwing the codes. I guess I'm going to have to replace the injectors.
Anyone have a favorite place to buy the injectors? The best deal I've found so far is $139 for rebuilt injectors on ebay. Last edited by Gus_hauler; 06-29-2012 at 08:04 AM. |
Warren Injectors! $500 for a whole set! Might as well do em all and not worry bout em!
