Hard srart no throttle and quite intermittent - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-17-2012, 04:31 PM Thread Starter
I have only had my truck for 6 months but it just started acting up sometimes it won't start I turn the key off try it again and it starts but its way quieter than normal the the other day I backed out of the drive way went to go and had no throttle help please. Thank u
05king is offline
post #2 of 4 Old 06-17-2012, 05:33 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Welp, that's vague. btw
Do you have an monitoring device? Cause if not, we're shooting in the dark here.
Quick ideas, bad battery/batteries: load test each one individually.
Bad battery connections. Clean no matter what.
Weak alternator. Check voltage once it's warmed up.
Bad/going bad FICM. Idk how to test it, but there are threads on here how to.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 4 Old 06-19-2012, 05:44 AM Thread Starter
Thank u I guess I was a little vague the batteries have plenty of juice I should have said it will crank but won't fire I also forgot to say I put an edge tuner on it for fuel efficiency and that made it smoke a fair amount but I have since programed back to stock and now I just have it there to monitor there are no codes I have heard it could be a bunch if thugs so I am lost
05king is offline
post #4 of 4 Old 06-19-2012, 10:04 AM
jesilvas's Avatar
Quoted: 2 Post(s)
Ok, batteries load tested? What about the other stuff?
I made my Samsung SGH-I997 send this.
4R100, 2wd
330,000 + miles
jesilvas is offline
