died drivn down road.. towed home
pulled codes when i got home
0046 0261 0264 0267 0270 0273 0276 0279 0282 0341 0401 0611 0675 2290 2291 2614 2617 cleared codes ran koeo self test came back with 0264 0267 0273 0279 0282 ficm volts at 47-48 ??? confused sounds like a ficm but ficm volts good? 04 f550 6.0 Last edited by zzamud; 06-14-2012 at 12:53 AM. |
While it is a good thing to know that you have the required 48vt that voltage has to be able to get to the injectors to do anygood. Wieing issues are one of the 6.0's more common problems. Loose plugs/connections, wire chafes, broken wires and corrosion of wires and terminals.
A quick field test is with the engine running wiggle and pull on the wire harness comeing from the ficm if the motor changes up or dies, then check the harness and connections. |
tested pin 4 on outside of ficm founr 19v at warm up 47-48v after and 36 at cranking |
FICM is dead It must be 48V ALL of the time.
MikeB |
yes ficm voltage is checked at cranking. general rule of thumb if it goes under 45 it is no good! but theoretically it should stay at 48 the entire time. but dying down the road isn't a super common ficm problem. ficm is usually only issues with cold start.
Solved. Hpop
yes that sounds like a died down the road problem
