Anyone have write-up or info? Camshaft removal - Ford Powerstroke Diesel Forum
Old 06-12-2012, 11:46 AM
I need to get the cam out of my 6.0L i have the block already torn down. Im about to remove the oil pan/ crank assembly. Does the camshaft just slide out of do I need a special tool?
Old 06-14-2012, 09:46 AM
Anyone have any tips?
Old 06-14-2012, 04:02 PM
Unbolt it with the block standing on end and then lift it out.
Old 06-14-2012, 04:26 PM
Feedback Score: 5 reviews
Can you please elaborate some more for us slow people
I have the same question..
Old 06-14-2012, 04:41 PM
think he means put the front of the block laying flat against the floor, lift the camshaft straight out top.
Old 06-18-2012, 04:37 AM
We always have the block split and the crankshaft removed when we do it and it just pulls right out but with the crank in the block, the spacer on the end of the crank would have to be removed first. If you are to remove it, make sure that you index it so that it goes back on exactly as it came off. You also have to have all of the lifters out.
