Happens after setting - Ford Powerstroke Diesel Forum
Old 06-08-2012, 03:49 PM
Truck is completely stock 6.0L 2004 F-250, owned since day one. After setting for atleast over night, when I start it up and and drive out of my drive way to the main road (a block) it runs fine, (under 2,000 Rpm). As soon as I hit the pavement and get up to speed and hit 2,000 Rpm's, it acts as if I have a Rev Limiter set and it blows greyish/whitish smoke. After driving for 4 miles under 2,000 Rpm's is clears up and run's normal. I can go everywhere all day and start it back up after setting for 2, 3, or more hours and runs normal. It happens after setting just over night (8 or so hours). No check engine light. Any ideas???
Old 06-15-2012, 02:06 PM
Well Just an update, I took the turbo off and it was free and absolutly no rust or carbon build up. So does anybody have an idea?
Old 06-15-2012, 02:49 PM
Check your egr valve and clean as needed may be sticking. allso clean your ebp sensor and tube.
Old 06-15-2012, 08:19 PM
agree absolutely with dannyboy! sounds like egr issue. however if there is no problems with your egr sucking then i'd recommend checking for exhaust restriction. try kicking your cat see if it is raddling around in there.
