White exhaust, coolant loss - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-07-2012, 09:12 PM Thread Starter
DVCF450's Avatar
Last year, 56,000 miles ago, had head gaskets, oil cooler,SCTs and studs put in. All stock. Last week developed a hairline crack in radiator at top hose inlet.
Have been adding and adding water. Some gold coolant, but not maintained the 50/50 mix.Been chasing the crack with JB Weld. Two days ago it developed a 'hollow leg', and took gallon after gallon of water. I can hear the water go [I]somewhere[I], but not until today found the puddle on the ground. Under the Muffler! Very, very sluggish starts, like my Optima yellow tops are drained. LOTS of white smoke under load, warm or cold. I took out the EGR valve and cleaned off the modest build up of carbon. Seemed to travel freely. Appeared to be dry, no moisture on valve or below it.
Truck is 2005 F-450 with 141k well maintained miles. 4X4 DRW. Hoping the forum can give me some ideas before I am relegated to the stealership.
DVCF450 is offline
post #2 of 7 Old 06-08-2012, 04:02 AM
Powerstroke Techie
Lilpooh's Avatar
Quoted: 10 Post(s)
Feedback Score: 3 reviews
Troubleshooting coolant loss (white residue around cooling system components(degas))
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #3 of 7 Old 06-08-2012, 05:06 AM
Blown EGR cooler. You are pumping the coolant through the engine cylinders. Better stop driving it until you get the cooler fixed. How are your ECT/EOT deltas?
It is possible you are stretching your head bolts if you are pumping that much steamn through the engine (yes even ARPs can be stretched).
MikeB
2005 F-250 6.0L, crew cab, long bed 4x4
completed in 2011: STC update, new IPR, BPD EGR cooler, oil cooler rebuild, 6.4 banjo bolts, blue spring update, SCT X3, Insight CTS, 58V FICM, CCV Mod, DIY coolant filter (now gone), refinished turbo
2012: ARP headstuds, OEM gaskets, standpipes and dummy plugs
2015: XDP coolant filter
PSDMikeB is offline
post #4 of 7 Old 06-08-2012, 06:33 AM Thread Starter
DVCF450's Avatar
Thanks Mike
That was my conclusion too. I read the thread about 'troubleshooting coolant loss', but my symptoms seem more severe. I see you have a BPD EGR cooler, how do you like it?
I am not sure how to go about this...fix it myself, hire a friend, or give it to the dealer. I know it's a big job after seeing last years' top end work. Theres alot of 'how to' write ups on these forums, but I'm an electrician by trade- not an ASME guy.
Thanks again for your reply!
Jon Howard
DVCF450
DVCF450 is offline
post #5 of 7 Old 06-08-2012, 09:28 AM
I have had the BPD cooler for a year, and no reason to complain. They claim to have a very low failure rate, if you have emission requirements, they are likely the way to go.
I am not a mechanic, but I was Bke to get it all done myself. If you can change struts, brakes, alternators and such, you can do an EGR cooler And oil cooler
MikeB
PSDMikeB is offline
post #6 of 7 Old 06-08-2012, 09:37 AM Thread Starter
DVCF450's Avatar
I am exempt from emission rules-as of now-in this zip code. That of course is subject to the whims of Sacramento. I have had the dealer do all my service since Nov 2004, when I bought it. Better times then, and I may be forced to do it myself this time around. Being my only vehicle, with customers' jobs upcoming, it is a tad stressful. I just hope i did'nt stretch those studs or gaskets with this blow out.
Thanks again for your experience
DVCF450
Jon
P.S. what is Bke?
DVCF450 is offline
post #7 of 7 Old 06-08-2012, 10:14 AM
Haha fat fingers and little keys.... I was able to get it done
PSDMikeB is offline
