Nightmare trip...truck engine stalling every 32 seconds like clockwork for 150 miles - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-04-2012, 10:45 AM Thread Starter
Hi Powerstrokers - I have a 2003 Excursion with early build 6.0. 135,000 on the ticker, no mods.
Never any trouble until last year I had the FICM rebuilt due to low voltage output with hard starting issue and replaced the ICP sensor due to an erratic idle.
Going to the beach this past weekend and after dropping the boat in the water, the engine dies trying to park at the ramp. It restarts; I say OK we'll see what happens when we get back.
It was stalling out every 32 seconds (I am not kidding, we timed it with a digital watch) It was to the point you could count up to 31 and point your finger and sure enough it would die.
It did not matter the speed, load, anything. We stopped at a store and I tested it in the parking lot, at idle....32 seconds on the money!
It is throwing a P2285 code, ICP sensor reads low.
If you goosed the pedal it would jerk the rpm up to 1500-2000 or so and belch black smoke out the tailpipe. I had some very, very pissed off folks behind me. I figure out if when it dies I put it in neutral, the engine would completely dies and I could restart it for the next 32 seconds at least.
I got home by putting in neutral, restarting and then back in drive going about 40-45 the entire way.
What is strange is we had a 1/2 tank fuel and the miles to empty overhead gauge stopped counting down, it was frozen showing 202 remaining for several hours.. So we are limping home and about 30 miles from the house the stalling issue decreased cycle time to 50 seconds or so, and then went away completely! The miles to empty gauge went from 202 to 100 instantly.
It has since stopped only three times from when I dropped off my crew at their houses and then me going home. This morning coming to work, the truck ran great.
Is the 32 seconds and miles to empty gauge frozen clues to something in particular? Bad fuel, clogged fuel flow sensor or line? Fuel filters were changed last month.
Had to leave the boat in storage at the beach, did not want to risk anything with the stalling and trying to tow something back at the same time. Engine dies so does power brakes and steering, had a couple of questionable stops twice along the way.
Bright side is we caught fish and I have a definite excuse to get back to the beach soon as the truck is fixed!
Any insight to this issue is appreciated!
Scott_K is offline
post #2 of 8 Old 06-04-2012, 12:04 PM
Slacker
Evil Eye's Avatar
Quoted: 190 Post(s)
Feedback Score: 4 reviews
Unfortunately, these are the same symptoms for most everything that goes wrong with the 6.0 engine... It could be that you have multiple issues, but I wouldn't give a whole lot of consideration to the overhead gauge issue or to the timing of the stalling. It's probably something else. I'm leaning towards a high pressure oil leak or an issue in the HPOP system.
The early 6.0's have known issues with the ICP pigtail getting saturated with oil causing erratic issues like you describe, so I'm hoping that since yours was replaced, that isn't your issue. Has your Excursion repeated this behavior since you had your issue? If not, that's going to make it difficult to troubleshoot.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #3 of 8 Old 06-05-2012, 06:18 AM Thread Starter
Shawn - The truck has ran normally through driving in town and back and forth to work since the issue happened. I have not put more fuel in it, but will need to in the next day or so from my trusted source near the house.
I think indicators are leaing towards needing to change the ICP and the wires again so I am gearing up to do that, clear the engine light, and then find something heavy to pull and see what happens.
Will report back after I do all that.
Scott_K is offline
post #4 of 8 Old 06-05-2012, 06:32 AM
Slacker
Evil Eye's Avatar
Quoted: 190 Post(s)
Sounds good, buddy. Keep us posted.
Shawn Carlson
Proud Navy Vet
Engine Mods:
Fluidampr
4" MBRP Exhaust
MTW Stage 1 Turbo
Exterior Mods:
Evil Eye is offline
post #5 of 8 Old 06-05-2012, 06:37 AM
Quoted: 48 Post(s)
really strange. buddy of mine had an '08 Dodge that would run/drive perfect. but when you shut the truck off, every 30 seconds you would hear all of the solenoids under the hood buzz/click/etc. the lift pump would cycle on/of like somebody was hitting the key and turning it off.
every 30 seconds exactly you could launch the space shuttle off of it
I put a spare ECM on it and it started doing it as soon as I reconnected power, so that wasn't it. I suspected it was the TIPM. He put the ECM on a toggle switch! LOL
complete and total tangent from your issue and zero help, BUT I do know how surreal it is for an "intermittent" problem to be perfectly timed
drunk on diesel is offline
post #6 of 8 Old 06-05-2012, 06:56 AM
atvrider93's Avatar
Quoted: 8 Post(s)
A fuel delivery issue wouldn't have that exact timing. I think I would fix it based on that code so it sounds like you're on the right track
Sent from my DROID BIONIC against my will
1996 F350 4x4 CCLB-- I'll miss her
1996 F350 4X4 RCLB zf5 213K
6637
OBA w/horn
DE 5"
PHP tunes
Mud Country 315/75/16
2008 Wr250X
Originally Posted by belz View Post
There u go Tom. John may not be sexy, but he can tutor you, lol.
atvrider93 is offline
post #7 of 8 Old 06-05-2012, 07:46 AM
jimmyv13's Avatar
Quoted: 46 Post(s)
Feedback Score: 3 reviews
Send a message via AIM to jimmyv13 Send a message via Yahoo to jimmyv13
Does the PCM monitor something at 32 seconds after start up?
2005 F250 CCSB Lariat FX4
4" MBRP Turbo Back*Sinister Coolant Filter*SRL+*'10 Tailgate*Dicad EGR delete*Premium EdFICM*Powerslot Rotors*Hawk Pads*Riffraff boots*DIY CCV*ARP's*'10 Tails*N-FAB Steps*'12 Rear Bumper*Dashboss*Pioneer DVD*'08 Trans Pan
*Bullitt y-pipe*'14 PE PF Mirrors*Fox 2.0 IFP*'08 Diff Cover
jimmyv13 is offline
post #8 of 8 Old 06-05-2012, 08:00 AM Thread Starter
That was kind of my point of putting that detail in there, it would vary a little between 32 and 34 seconds, maybe the way we were starting and stopping the wristwatch timer. I was thinking what in the world is looking for some condition after startup and the initial sensor sweep?
That timing and the miles remaining gauge are curious clues to this in my mind. I have the parts ordered, will know hopefully in a few days.
Scott_K is offline
