Fan clutch? - Ford Powerstroke Diesel Forum
Old 06-03-2012, 07:57 PM
Fan clutch?
What temp should the fan come on 100% It seems like my fan never comes on when I am towing. The temps get to the point where my Degas pukes Is there a way to test the clutch or not?
Old 06-03-2012, 08:55 PM
Do you have a EGR delete?
Side effect of disconnecting EGR valve
Old 06-04-2012, 10:14 AM
So after reading all of that It sounds like I need to put the valve back in. thanks I will give it a try and pray cause I am tired of all the working on this thing.
Old 06-04-2012, 10:43 AM
You don't have to put it back in the intake manifold just use the right rear intake elbow bolt going thru the EGR valve hold down tab to hold it from bouncing around and plug the electrical connector back in. I use a machined spool in place of the actual EGR valve in the intake manifold. Just do a search on eBay for "EGR spool", it costs around $70.
Old 06-04-2012, 11:41 AM
So would I need to turn the setting on my sct to ON when I plug it back in for the fan to work right? Or is that just for the CEL?
Old 06-04-2012, 06:18 PM
I would think you could just plug it back in.
Old 06-04-2012, 06:21 PM
don't turn the EGR to on ,, and not all trucks need the EGR plugged in ,, but give it a go
