Fuel leak at Banjo bolt or plug right below it? - Ford Powerstroke Diesel Forum
Old 06-03-2012, 08:47 AM
Yeah it's a Turbo Diesel
Feedback Score: 8 reviews
Well I went to change my oil today and noticed some kind of residue all over everything..it was diesel. So I turned the key on, got under the truck to inspect the leak if I could see it, saw a lot of diesel dripping, got above the engine compartment and looked around, I could see a good trickle coming from the Banjo Bolt area.
I can't tell if it's coming from the banjo bolt itself, or that freeze plug with the blue dot right below it. Anybody dealt with this before? Or know how to fix it?
See the pic below: Passenger side banjo
Any help is appreciated!
Old 06-03-2012, 08:53 AM
make sure the fitting isn't cracked, if not get a new set of copper washers from ford.
Old 06-03-2012, 09:00 AM
Thanks! I'll get those tomorrow. I tried tightening the banjo, but could hardly get an 1/8th of a turn on it. When I replace the copper washer, is there a torque spec or just tighten till snug and do a 1/4 turn? Also, do I need to work fast to keep from losing diesel or does just whatever is in the supply leak out?
I appreciate the help man!
Old 06-03-2012, 03:10 PM
I think you'll get a tad bit of fuel to run out once you undo the banjo but as long as the key isn't in the on position it will stop dripping pretty quick.
Old 06-03-2012, 06:08 PM
There is a torque spec. I have it at work ill post it up here tomorrow.
Old 06-04-2012, 07:04 AM
Ok, banjo washers replaced...Not the fix! I believe it's the fitting on the hardline, it was still spraying out diesel, Here's a video of it:
Stealership will have the hardline in tomorrow morning..Any tips on replacing it? I think I'll be able to snake it around the fan shroud housing, Hope I don't have to take all that sh!t out!
Old 06-04-2012, 08:25 AM
torque on the banjos are 28 lb-ft. You should be able to snake that line out.
Old 06-04-2012, 01:12 PM
man, any tips for getting this fuel line out? It is a b¡tch!!! it's looking like I may have to take off that fan shield and some other stuff...I gotta get it fixed today/tonight it's my only truck!
Old 06-04-2012, 02:25 PM
You ain't holdin your mouth right....
Sent from my SCH-I500
Old 06-04-2012, 03:51 PM
Oh ok, torqued it to the left n right a lil bit! I had to loosen the fan shroud 4 bolts, and that elbow on the intake that is fed by the intercooler. Had to bend the tube just a scoach.
