replaced bad ficm still no start - Ford Powerstroke Diesel Forum
Old 06-02-2012, 07:22 PM
03 f350 began to die intermittantly. No injector chatter on KOEO. Ficm volts were way down. Had ficm rebuilt. Truck started great ran about 100 yards then died. No injector chatter. I have completely removed and inspected the fuel injector harness (repaired a bad short on two injector wires). After reinstalling harness I get injector chatter and good start, truck runs for about 3 minutes then dies and we are back to no injector chatter. FICM voltage is 48 and I replaced the ficm relay. Any ideas? I'm quickly getting to my wits end. Thanks
Old 06-03-2012, 03:44 AM
Please check your fuel pressure.....
Sent from my SCH-I500
Old 06-03-2012, 06:23 AM
I will check it today, will low fuel pressure cause a loss of injector chatter at KOEO?
Old 06-03-2012, 06:47 AM
Uhm...no I don't think so, missed that part.....sorry.
Old 06-03-2012, 06:48 AM
Just Ficm voltage at 48 alone, does not mean your ficm is ok.
Old 06-03-2012, 07:11 AM
that is what I'm leaning towards, the ficm is still bad. I ordered a new injector harness (to eliminate that as a possiblity, I did find and repair rub spots in a couple of places.) The Batteries have been load tested, alternator is good, HPOP is less than a year old. Is there anything else that would cause the chatter to stop (if it chatters it will start, no chatter no start)
Old 06-06-2012, 11:55 AM
Found really bad short between two injector wires, ficm was fooked, I'm assuming from the short. The main harness has had an end spliced on to it (x3) I checked all of the wire colors and their corresponding pins, they match. Is there a way to ensure that the 5 ground wires (black/pink) and switched power (dark green/light green) are attached to their correct wire? Or does it even matter as it appears they are fed by a common ground or switched common bus? I just want to make sure I don't blow another ficm
Old 06-06-2012, 04:27 PM
Sounds like you may need a harness.
Old 06-06-2012, 04:49 PM
I ordered a ficm harness, hope that cures it
Old 06-06-2012, 05:03 PM
Tousley fords prices can't be beat. Hope thats it. How much do they run, I need one too, I have a cracked plug. No running issues yet.
