Fires but no start - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-02-2012, 02:51 PM Thread Starter
jessemac's Avatar
Fires but no start
Its has been forever since I posted but here goes, I have a 03 F250 6.0 egr delete. sct livewire, Towed a truck back to were I live appx 220 miles truck run great, have been noticing that for past couple weeks truck has been taking extra couple secs to start and takes awhile longer to really run good after startup, Now after i got back from trip ran truck appx 50 miles next day and didnt drive it for the rest of week went to start it saturday morn and it would try and start but would only run for appx 2sec and die lots of smokeout of exhaust but would not stay idling, it was appx 80 degrees out this day, i plugged truck in just trying to figure out and 2hrs later went back out and truck fired right up idling smooth when i tried to push gas just in park it wouldnt idle up at all then i let it warm up for appx 20min went out pushed gas and it was running great, so wat i am getting at is truck wouldnt run unless plugged in. So i figured it was glowplug module i ordered put it in and same thing tries to fire but wont start so i have known for awhile that my icp sensor was leaking oil so i started replacing that today, but my ? is is there anything else this might be or am i on the right track? any help would be great thank you in advance.
Also truck went from running appx 200 miles a week to maybe 20miles due to me getting company pickup about 3 months ago. doubt it has anything to due with it but thought I would say. I really need this going so i can go to mtn tomorrow. Thanks again i do have turbo off and icp changed has of now if there is anythin else i can check while its off.
03 6.0 F-250
livewire- Tuned by matt/eric
afe stage 2
4inch turbo back
Sinister egr delete
Homemade trac bars-Bent
New ladder bars in fabrication
sct sticker on side worth 20hp
powerstoke sticker on windsheild- 22.6hp
My lugnuts require more torque then your engine makes on back window- priceless
jessemac is offline
post #2 of 3 Old 06-03-2012, 12:36 PM Thread Starter
jessemac's Avatar
Just an update I got my icp sensor changed out and everything back together and its is still the same If i plug it in for a couple hours it will start and idle amazing, tried to drive it today and as soon as it is under any kind of a load it starts cutting out and wont really go anywhere....... there are no codes and no check engine light, does anyone have a idea of wat i should do next or where to look next? could this be a fimc issue? any help would be great thanks alot!!!
03 6.0 F-250
afe stage 2
4inch turbo back
Sinister egr delete
jessemac is offline
post #3 of 3 Old 06-04-2012, 09:39 AM Thread Starter
jessemac's Avatar
Bump
Sent from my DROID RAZR using AutoGuide.Com Free App
03 6.0 F-250
afe stage 2
4inch turbo back
Sinister egr delete
jessemac is offline
