2003 power loss 6.0 - Ford Powerstroke Diesel Forum
post #1 of 10 Old 05-22-2012, 07:47 PM Thread Starter
2003 power loss 6.0
Help got 6.0 that has loss power can't get out of its own way replaced ficm last year and tested again shows good. Replaced leaking icp ( what a job ) .and removed turbo and cleaned veins and ring thinking that was it .and pulled egr and cleaned again not really dirt this time. The truck starts fine idle fine and no stalling just no power .
brian4430 is offline
post #2 of 10 Old 05-24-2012, 06:55 AM Thread Starter
somebody help me losses power past 1/4 throttle
post #3 of 10 Old 05-24-2012, 09:24 AM
My Dream's Avatar
There is an electronic solenoid on the side of the turbo that controles the VGT. If that is not working, the turbo may not be generating any boost. I am not sure how to test it though, sorry I'm not much help.
James
2003 Silver F-250 6.0L Auto, Lariat, 4x4, CC.
Zerex ELC coolant.....
Ford Air filter....
Banks Automind handheld running eco tune
Banks monster sport cat back system w/CAT delete pipe
Bullet Proof system, ARP head studs.
Pro Comp 4" lift W/MX6 adjustable shocks
35" goodyear Dura Trac tires.
My Dream is offline
post #4 of 10 Old 05-24-2012, 09:36 AM
roche837's Avatar
Quoted: 6 Post(s)
Garage
Feedback Score: 4 reviews
How many miles on the truck/ Any codes?(may not trip the CEL) i had a p2290 for low ICP pressure and my issue turned out to be the HPOP.
Check:
ICP actual
ICP desired
IPR %
at idle you should see above 650psi for ICP (truck wont start unless above 500 psi)
off throttle will vay but should see 1500-2000psi
full throttle on an 03 or WOT should be around 3000 psi
EMPIRE STATE STROKERS
Studded, 5" exhaust, Sinister EGR DELETE / Coolant Filtration, more to come
roche837 is offline
post #5 of 10 Old 05-24-2012, 09:37 AM
roche837's Avatar
Quoted: 6 Post(s)
Garage
Here is my thread has some good info in it:
Sudden loss of power
hope it helps
roche837 is offline
post #6 of 10 Old 05-25-2012, 11:43 AM Thread Starter
great thread roche837 i am in the middle of reading and trying things out . i will give more info on truck 2003 excurion 6.0 153000 miles just added scangauge11 and in process of adding x codes installed fuel gauge into test port got 55lbs all time what is a epb sensor ? icp pressure at ilde is 880 just rev-up goes to 2200 with out load going on test drive soon. by the way no codes
post #7 of 10 Old 05-26-2012, 04:01 PM
roche837's Avatar
Quoted: 6 Post(s)
Garage
EBP (Exhaust Back Pressure) sender it is bolted to the T-stat housing on an 03,
From what i understand it does not get used by the PCM on these models, instead it uses mass airflow.
I would check the ICP connector for oil, if it has oil it has failed.
roche837 is offline
post #8 of 10 Old 05-27-2012, 06:53 AM Thread Starter
Thanks the icp has been replaced because of leaking oil and now working on replacing bps doto it breaking off when checking for buildup nice! Is that why no reading from bps from scangauge11. So I bought new bps and mass air sen going to try this afternoon .
post #9 of 10 Old 05-27-2012, 08:24 AM Thread Starter
hpop down on test drive now no start hahafun for me
post #10 of 10 Old 05-27-2012, 10:43 AM
Ok before ya just thrrow parts at it Read the sticky on the 6.0 problems forum. An exellent write up on no start/hard start issues. It contains symptoms, tests and common fixes. Best info I can give at this point. By the way when ya changed the icp did you change the pigtail also. When the icp leaks it useually gets oil in the pig tail a common failure.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
