6.0 runs rough at idle and cruising speeds - Ford Powerstroke Diesel Forum
post #1 of 11 Old 05-17-2012, 06:26 PM Thread Starter
Angry 6.0 runs rough at idle and cruising speeds
My 03 6.0 runs real rough at idle and at cruising speeds on the highway. It progressivly gets worse the warmer it gets. When at highway speeds (running rough) you can throttle up, black smoke rolls out, and it runs fine till you hit overdrive again, then back to rough. I've taken it to several shops, all with different answers. But what i do know is that #2 injector is only firing when under power. I have replaced the motor (with a rebuild),#2injector twice,hpop,oil cooler, egr delete, glow plugs, checked ficm, injector harness, new icp and pigtail, fuel pressure is good. It's been at another shop for the last 9 wks the guy wont even work on it any more! ANY SUGGESTIONS?????? PLEASE I NEED HELP!!!
pickup man is offline
post #2 of 11 Old 05-17-2012, 08:12 PM
Powerstroke Techie
Quoted: 383 Post(s)
throwing any codes?
i know it's a rebuilt, but maybe there's a problem with the motor. try checking for blow by.
then, KOER, disconnect #2 injector. see if idle falters. this will confirm an issue with that cylinder
kaya is offline
post #3 of 11 Old 05-18-2012, 09:57 AM
i recently did head gaskets, head studs, and a egr delete on my 03 6.0. Before i did it truck ran fine just did it so the truck would hold up to my horse power. Now truck is throwing a cylinder #1 code and at a idle it is only running on 7 cylinders but when you take off all 8 come back. also now after doing the work i did my truck rolls white smoke constantly. Plus it has a lope idle now. can someone please help.
samarmstrong57 is offline
post #4 of 11 Old 05-18-2012, 12:27 PM
southend's Avatar
you said ficm is ok, just showing correct voltages does not mean it is ok. You can also ohm check the suspect injectors. It is giving you a #1 code for a reason. Investigate that. maybe you need to look at the push rods, and rocker arms again......?
Sent from my SCH-I500
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #5 of 11 Old 05-18-2012, 07:20 PM
Powerstroke Techie
Quoted: 383 Post(s)
hmmm. is it an injector 1 circuit code? or contribution?
if it's contribution, KOER, remove the oil filler cap. check the blow by.
have a funny feeling you may have installed a push rod ****ed
kaya is offline
post #6 of 11 Old 05-19-2012, 02:38 PM Thread Starter
The ficm was sent to some one in texas and checked it out and it was good. The only codes that come up are #2 contribution. When its hooked to a computer and they shut down #2 nothing changes. But again that injector has been changed out 3 times with no difference. The guy thats working on it said he has pulled the head off and can"tfind anything wrong,he also did a compression test and it was within specs
post #7 of 11 Old 05-19-2012, 03:17 PM
Only thing I can see is a wireing problem that injector is not receiveing any signal from the FICM or the scan tool and is just not fireing at all.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #8 of 11 Old 05-19-2012, 07:43 PM
Powerstroke Techie
Quoted: 383 Post(s)
that should normally cause a circuit code though.
you're positive the push rods for that cylinder are ok? because bent push rods won't cause a loss of compression, but will cause a misfire. and it's easy to throw those push rods in slightly off the lifter when doing a head job.
and just to confirm, was it cyl 1? or 2?
kaya is offline
post #9 of 11 Old 05-19-2012, 08:30 PM
Kaya I would agree but there has been 3 different injectors in the same hole. Heads have been pulled and inspected reinstalled and checked with the same problem. Do ya think his mechanic put bent push rods back in the same place again?
post #10 of 11 Old 05-19-2012, 11:43 PM
Powerstroke Techie
Quoted: 383 Post(s)
well, if he's keeping everything in order like he should, he would put them back in the same place. but ya, if you're pulling the head off a second time, you're looking for anything and everything. one would hope something that obvious wouldn't be overlooked
too bad you can't run a buzz test on the 6.0's. that would come in handy right here.
guess it's time to break out the multimeter and check the circuit.
power probe would be best though
or i wonder if you can do like a gas vehicle and check for injector pulse with a 194 marker bulb. that would be ideal
kaya is offline
