Low fuel mileage - Ford Powerstroke Diesel Forum
post #1 of 11 Old 04-17-2012, 09:23 AM Thread Starter
Chapter Director
psd_va's Avatar
Low fuel mileage
Hey guys so I know this topic comes up a lot but I have a few questions. This past weekend I towed my boat (about 2500lbs) about 170 miles and used half a tank of fuel which doesn't seem right. Now I know I need to change air and fuel filters but my question is how bad can those affect mileage? I'm not expecting real high mileage out my truck being on 38x15.50 tires but I was hopping for more than im getting. can a gutted cat with out a pipe through it hurt flow and in turn hurt my mileage? I had other questions in my head but can't think of then right now but when I do I'll post them.
03 F350 6.0 SRW 4X4 lariat
481hp 832tq
8" super lift 385/70r16 Toyo MT's
FatBoy traction bars
Durastroke stg1
intake
MBRP 5" straight pipe
Custom tuned by Vivian "Looney Wild Track"
Edge Insight CTS
Zoodad mod
high idle mod
6.4 banjo bolts
Updated fuel pressure regulator (Blue spring mod)
EGR cooler delete
6K 55w HID's
6k 35w fog HID's
B&W turnover ball
psd_va is offline
post #2 of 11 Old 04-17-2012, 03:04 PM Thread Starter
Chapter Director
psd_va's Avatar
Any one able to help me out
481hp 832tq
Durastroke stg1
intake
Edge Insight CTS
Zoodad mod
high idle mod
6.4 banjo bolts
EGR cooler delete
6K 55w HID's
6k 35w fog HID's
B&W turnover ball
psd_va is offline
post #3 of 11 Old 04-17-2012, 03:07 PM
jesilvas's Avatar
Quoted: 3 Post(s)
Well, how full was the tank before hand?
It's not really accurate to go off the gauge. Best way is fill it full, run it getting mileage, fill it the same way again, and then find your miles traveled divided by your gallons filled up.
If the air filter is dangerously clogged it might do something, but you'd have other problems by then. Fuel filter, you might get low mileage also, but nothing drastic I don't think.
A gutted cat, and a free flowing exhaust for that matter, will HELP your mileage.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #4 of 11 Old 04-17-2012, 05:11 PM Thread Starter
Chapter Director
psd_va's Avatar
I stopped and filled tank till it clicked before I hit the road. Haven't really noticed anything else other than a weird inconsistent idle every now and then.
481hp 832tq
Durastroke stg1
intake
Edge Insight CTS
Zoodad mod
high idle mod
6.4 banjo bolts
EGR cooler delete
6K 55w HID's
6k 35w fog HID's
B&W turnover ball
psd_va is offline
post #5 of 11 Old 04-17-2012, 06:13 PM
jesilvas's Avatar
Quoted: 3 Post(s)
The idle can be all kinds of things. HPO or fuel basically.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #6 of 11 Old 04-18-2012, 04:25 AM Thread Starter
Chapter Director
psd_va's Avatar
Well hpop is a year old. And I've done the 6.4 banjo bolts and blue spring mod. What can I check or test to see whats going on possibly
481hp 832tq
Durastroke stg1
intake
Edge Insight CTS
Zoodad mod
high idle mod
6.4 banjo bolts
EGR cooler delete
6K 55w HID's
6k 35w fog HID's
B&W turnover ball
psd_va is offline
post #7 of 11 Old 04-18-2012, 04:34 AM
jesilvas's Avatar
Quoted: 3 Post(s)
Check PIDs while running. ICP, fuel pressure.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #8 of 11 Old 04-18-2012, 04:55 PM
RedBKM's Avatar
How big is your tank? 2500lbs shouldn't phase you unless it catches a ton of wind. What do you get unloaded?
About 11mpg loaded (6k tractor + 4k trailer) and 16mpg unloaded is what I get with similar mods minus the tires.
2006 F350 PSD Lariat 4x4 SRW, 4" MBRP straight pipe, SCT X3 w/ ID Tunes, Edge Insight CTS, Sinister Coolant Filter, High Idle, Red
2013 F250 6.2L 4x4 (work truck) Factory E-locker, Warn Trans4mer M12000
1995 Mustang Cobra 5.0, Heads, intake, 65mm TB, headers, exhaust, 3.73s, Cobra Rs, 160k trouble-free miles, Red
2011 Mazda Tribute (Ford Escape) 2.5L, 4x4 & 27mpg= Thank you Ford, eBay heated seats, Red
'42 International K1 pickup, Green Diamond I6, 4 on floor, Red
RedBKM is offline
post #9 of 11 Old 04-18-2012, 05:44 PM Thread Starter
Chapter Director
psd_va's Avatar
Should be 29 gal tank with the short bed. I doubt it is catching a lot of wind seeing as the windshield is only about 6inches taller than the bed of my truck due to being lifted with drop hitch. Not sure what I'm getting unloaded I haven't filled my tank in a while just put enough in it to go where I need to go kind of thing.
481hp 832tq
Durastroke stg1
intake
Edge Insight CTS
Zoodad mod
high idle mod
6.4 banjo bolts
EGR cooler delete
6K 55w HID's
6k 35w fog HID's
B&W turnover ball
psd_va is offline
post #10 of 11 Old 04-23-2012, 07:56 AM Thread Starter
Chapter Director
psd_va's Avatar
So I changed my fuel filters but still to early to tell but I also dont think thats it. Still looking for other possibilities.
481hp 832tq
Durastroke stg1
intake
Edge Insight CTS
Zoodad mod
high idle mod
6.4 banjo bolts
EGR cooler delete
6K 55w HID's
6k 35w fog HID's
B&W turnover ball
psd_va is offline
