HELP....Rough runner, smokes, stalls - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-11-2012, 02:59 PM Thread Starter
Unhappy HELP....Rough runner, smokes, stalls
2004 4X4 F250 6.0 liter 100,065 miles. EGR delete kit, everything else stock. I changed the fuel filters and problem went away for 40 miles and came right back. It idles a little rough, blue or white smoke on startup. blue smoke while running, but not excessive. It will idle all day long, but if you climb a hill or get on it it will eventually stall. As soon as it stalled I turned the key off and the engine mounted filter was empty. Checked HFCM filter and replaced again with no help. drained H20 plug, no H20. Pulled bed and checked in tank pickup and it looked new. It is a plastic tank. All fuel lines look very good, internal o-rings look good. I replaced The fuel pump in the HFCM and thoroughly cleaned unit. Found some brownish mud buildup inside HFCM. Installed pressure regulator kit to boost fuel pressure, it was pretty dirty in there, I thought that was weird. After completion, problem is the same. A couple times it seemed like the engine almost hydro locked while cranking. I am almost stumped at this point, any help would be gladly appreciated!!!
Thank you,
John M.
jmuntean635 is offline
post #2 of 5 Old 03-11-2012, 04:28 PM
atvrider93's Avatar
Quoted: 8 Post(s)
I'm not sure about the blue smoke, that may be a separate problem. Sounds like its starving for fuel. I think a cylinder contribution test would be a good place to start. make sure you get diesel from a place that sells a lot of it. are you changing out your fuel filters every 10k miles? whats you FICM voltage?
1996 F350 4x4 CCLB-- I'll miss her
1996 F350 4X4 RCLB zf5 213K
6637
OBA w/horn
DE 5"
PHP tunes
Mud Country 315/75/16
2008 Wr250X
Originally Posted by belz View Post
There u go Tom. John may not be sexy, but he can tutor you, lol.
atvrider93 is offline
post #3 of 5 Old 03-11-2012, 05:06 PM Thread Starter
I may be wrong but if I pull the fuel filter off of the top of the engine and it is almost out of fuel, I believe I have a lack of fuel issue. Even if my tank was full of water, obviously it wouldn't run but the fuel pump would keep that fuel filter on top the engine full of whatever liquid you had in the tank. As soon as it stalls or near stalling i shut the key off, hurry and remove the fuel filter cover to notice it is near empty. Even if my FICM voltage was low or non existant that filter should be full right? I do change filters regularly and evertime the one on the engine was full of fuel. I am no expert by any means, I am just trying my best logic and any helpfull suggestions. What do you think?
post #4 of 5 Old 03-11-2012, 05:18 PM
atvrider93's Avatar
Quoted: 8 Post(s)
the line could be clogged, try blowing it out
6637
OBA w/horn
DE 5"
PHP tunes
2008 Wr250X
post #5 of 5 Old 03-11-2012, 05:21 PM Thread Starter
I pulled all fuel lines feed and return, clean and clear
