New to my 6.0 and diesels in general - Ford Powerstroke Diesel Forum
post #1 of 10 Old 03-07-2012, 11:14 AM Thread Starter
Just bought my first diesel last week. I bought a 2007 F250 single rear wheel crew cab Lariat FX4 with 139K. Bought it in Houston and drove back to Indiana. It drove great and got ~22 (by the lie o meter) on the highway. I has reset the mileage gauge just to see hwy mpg so it shouldn't match. The overall for the whole trip was 20.9 by hand calc. Also getting a not too bad just shy of 15 around town by hand calc.
Once getting to Indiana, despite our warm trend, we had a few cold mornings. I had the rough start issue. Took to dealer and had them go through it with a fine tooth comb. Everything checked out great but, they told me what you all had already taught me which is that the injectors were having stiction issues. Of course they recommend replacement with the nice heavy pricetag. Although they were honest and said everything should clear up with the warm weather until next winter. First I am going to give Rev-X a go and see what that does. I've also just added my first additive to the fuel to improve lubricity and cetane. I put Diesel Kleen + in this afternoon to see if that helped quiet the injectors down a little. Still waiting on the Rev-X. I plan to go full synthetic at the next oil change too.
Thanks to all the posters/repsonders for all the education before the purchase and now afterward. As I learn my about my 6.0, I'll try to contribute as well.
gadevrie is offline
post #2 of 10 Old 03-07-2012, 11:16 AM
Quoted: 356 Post(s)
Feedback Score: 5 reviews
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is offline
post #3 of 10 Old 03-07-2012, 12:22 PM
Shotgun_girl's Avatar
You certainly came to the right place! You'll get a schoolin' here!
I sure hope you have better luck with your 6.0 than I have
Nikki
It spends a lot of time on the rollback
2004 6.0 F350 FX
Straight pipe
AFE cold-air intake
Sinister EGR delete
SCT tuned
Dieselsite coolant filter
Blue spring
6.4 Banjo Bolts
Things replaced:junk gold coolant
two injectors
2 alternators
oil cooler
2 FICM (one replaced before I purchased)
some little transmission part (easy $16 fix)
IRP valve & HPOP
gasket on turbo
degas cap (easy fix $4)
no doubt there will be more to come...it is a 6.0
Shotgun_girl is offline
post #4 of 10 Old 03-07-2012, 12:25 PM
buckels's Avatar
Send a message via AIM to buckels Send a message via MSN to buckels Send a message via Yahoo to buckels
Welcome to the Org
Posted via Autoguide...Enabling my addiction!
Drew
99 SD 6SPD manual
AFE Intake
Diamond Eye 4" turbo back exhaust
Wicked Wheel Gen2
PHP Hydra tunes by Bill
If you live in WA or OR check out these links.
buckels is offline
post #5 of 10 Old 03-07-2012, 12:31 PM
Originally Posted by buckles24 View Post
Welcome to the Org
LOVE the Autoguide!!!
Nikki
2004 6.0 F350 FX
Straight pipe
AFE cold-air intake
Sinister EGR delete
SCT tuned
Blue spring
6.4 Banjo Bolts
two injectors
2 alternators
oil cooler
IRP valve & HPOP
gasket on turbo
post #6 of 10 Old 03-07-2012, 01:39 PM
RTR stroker's Avatar
Welcome to the .org! You are on the right track with swapping to synthetic oil. Alot of people say that it has helped their stiction problems. And i ALWAYS put some kind of additive in my fuel, its a good ritual to get use to doing. And you should look into getting some gauges or a way to monitor your vitals. Enjoy your 6.0
T.J.
- 2004 F250 FX4 crew cab -
* 4" MBRP straight pipe TB 5" tip
* "blue spring" upgrade
* 6.4 banjos
* A pillar triple gauge pod (egt,boost,trans temp)
* 2" leveling kit
* 35" yoko's
* 05' headlights(soon to be front end)
* 08' Taillights
* CCV reroute
* EGR Delete
* Sinister coolant filter
* Riff Raff boots
* Rotella T6
RTR stroker is offline
post #7 of 10 Old 03-07-2012, 02:41 PM Thread Starter
I put the 16oz of diesel Kleen in and drove about 30 minutes. Tank was nearly full. Temp outside same as yesterday so good comparison. The truck is running so much better. The cetane bump must have been needed. I think the Meijer diesel I run only has about a 50 Cetane rating. Can't wait to get the Rev-X and clean out the other end of the injectors.
gadevrie is offline
post #8 of 10 Old 03-07-2012, 03:16 PM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #9 of 10 Old 03-08-2012, 07:00 AM Thread Starter
Got my Rev-X today...never been so excited about an oil additive in my life! LOL It'll be harder to compare now since we've had a warm up here in Indiana. Although I think it's dropping below freezing tonight so tomorrow AM start will be a good test after running the Rev-X today and tonight.
gadevrie is offline
post #10 of 10 Old 03-19-2012, 12:06 PM Thread Starter
Rev-X seems to once again have done the job. I am new to diesels so this may be "normal". It is still a little rough for about 10 seconds after starting on a cold morning, but then it settles right in. Onceit is warmed up and I am crusing along, it is not much different sounding than a gasser. My plan oging forward is to use full suyunthetic at the next oil change and another 2 bottles of Rev-X (going to one bottle per after that one). I have my EGR delete kit in hand waiting for a full day of time to do it. Also bought a test pipe to let things flow through the turbo a little more freely. The Power Service added really helped smooth things out too. My injectors sound much happier. I also plan on hooking up my laptop and OBD connector to check out the sensor values (esp EOT and ECT) next time I drive it. Is the fuel pressure soemthing I should be able to read through the OBD as well? Haven't hooked up the laptop and software to this truck yet.
gadevrie is offline
