Truck died while driving and wont start - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-05-2012, 05:59 PM Thread Starter
Exclamation Truck died while driving and wont start
I hope someone out there can help me! The deal is.... I have a 2005 6.0L PSD with 115,000miles on it. For a while now I have been dealing with some strange issues. The truck will not start if temp outside is below 45 unless I really crank on it. I am assuming I have a glow plug or cold start issue there. If I plug it in everything starts great. Once the truck is started it runs poor and dumps white smoke everywhere. Even after the truck is up to temp the smoke continues. It also started cutting out everytime I would pull away from a traffic light and would take a min for it to catch up... almost like i was flooding or not getting fuel. Every now and then when Im driving about 55mph and 1500rpm the truck seems to cut out or jump. Finally the other day I was rolling to a stop at a light and the truck just died. When I put my code reader on it the only code to come up was for a crank shaft sensor. I have replaced the sensor and still nothing. The truck cranks freely and fast but nothing. I have also removed the egr valve (during the time it was still running) and did my best to clean it up. There was a lot of black tar like material everywhere. Now when I turn the key I can hear the fuel pump running under the driver door. Any Ideas??? Hope someone knows whats going on because I am lost! FCIM??? High pressure oil pump???
wildwilly2005 is offline
post #2 of 3 Old 03-06-2012, 11:26 AM
Quoted: 12 Post(s)
I'm not a tech but it sounds like an egr cooler leak. I had the same symptoms you have and had to replace oil and egr cooler. If your egr valve was moist which it sounds like it was I would think it is the egr cooler. Good luck maybe a tech can give you more advice. Also might want to give more info about your truck. That might help them diagnose.
Do you have gauges to monitor oil and coolant temps? If you do, see if the difference in temps is below or above 15* at fully operational temp. on the hwy. doing 55-60 mph for a straight run for about 10-15 minutes. If it (delta) rises above 15 you probably have an EGR cooler leak.
2006 F-350 6.0 Fx4
EGR delete
Dieselsite Coolant bypass filter
Edge CTS Monitor
Blue spring
Rotella T-6
Updated STC HPOP Fitting
SCT Tuner w/ Matt's tunes & Chris
Atlas 40 FICM tune from Ed
240,000 miles
05 Pstroker is offline
post #3 of 3 Old 03-06-2012, 01:01 PM
Sinister Diesel Sucks!!!
michaelaiman's Avatar
Quoted: 275 Post(s)
Black goo in your EGR circuit and white smoke sounds like a ruptured EGR cooler to me. Have you checked your coolant level? If its gone low for no apparent reason, then egr cooler is definately suspect. I wouldnt keep driving it like that or you're going to end up having to do head gaskets as well. but for now, replace your oil cooler, and egr cooler, or delete the egr, flush your cooling system and switch to CAT EC-1 ELC rated coolant.
03 F350 SD 6.0 PSD FX4 XLT CC LB SRW FOR SALE!!
To see why you should avoid Sinister Diesel, visit these threads:
michaelaiman is offline
