need a little help guys - Ford Powerstroke Diesel Forum
Old 03-03-2012, 09:22 AM
2005 6.0 runs perfect cold drive it 30 or 45 miles and it stalls like its out of fuel i can cycle the key three or four times and fill the fuel bowl back up and it will run for a little while then it does it again and sometimes it dont do it at all new fuel pump a few days ago egr delete new stc fitting rebuilt oil cooler new ipr what could it be
Old 03-04-2012, 01:07 PM
it could be a bad icp sensor, thay can read bias and do a bunch of goofy stuff. it could also be a cam or cranks sensors. best bet is to see if you get any codes out of it and go from there.
Old 03-04-2012, 02:56 PM
thanks for the reply i took it by auto zone no check engine light and they said there was no codes guess its gona have to go to the ford place hate that since they dont seem to know a whole lot
Old 03-04-2012, 03:31 PM
Honestly if you can find a local shop that serves International, Fords, or both you maybe better off than if you took it to the stealership, especially if they don't know that much. Just my .02 cents.
Old 03-06-2012, 02:18 PM
well for an update took it to ford and after 325.00 they said the lines had trash in them they blew them out and it ran good coming home we'll see
