6.0 problem - Ford Powerstroke Diesel Forum
Old 03-01-2012, 04:40 PM
6.0 problem
Just did head studs on a 6.0. Had heads checked and just needed to milled. Put the truck together and tried to start it it would just crank. My buddy put started fluid and got it to start. Truck started blowing white smoke out of exhaust. Come to find out the dowl pins needed to be shaved down too. Causing the heads to not sit flush. Water was passing through the gasket. Pulled it apart and found a bent pushrod.
Once again i shaved the dowl pin and put it back together and started it up again. Truck had a slight knock so I took it apart again found another bent push rod. Do you think milling the heads could have cause all this problem?
Old 03-01-2012, 05:39 PM
Send a message via Yahoo to roustabout04
If they took off too much surface area then clearance issues are your problem causing the bent pushrods. I may be wrong but these heads arent supposed to have more than
.020" off or you run into the problem your having now.
Old 03-01-2012, 06:14 PM
They didn't mill them that much. I'm thinking it's cause they were putting starting fluid in the engine to start and since the oil hadn't ran throughout the litters and stuff could have had something to do with that. I have no signs of a valve hitting a piston..
Old 03-02-2012, 03:55 AM
Idk then. Hopefully you get it all straightened out.
Old 03-02-2012, 04:05 AM
Did you set the timeing mark at 6=oclock when ya torqued the rockers.
