copper flakes in oil - Ford Powerstroke Diesel Forum
post #1 of 9 Old 02-27-2012, 11:18 PM Thread Starter
Making ported intakes
ODAWG714's Avatar
Quoted: 6 Post(s)
hey guys. heres the deal. i did a 70k oil change on saturday and noticed some very thin tiny flakes on the funnel the oil drained into. i also noticed this last year 5000 miles ago when i changed the oil. the truck has no issues nor knocks or loss of power. and i inspected the oil filter inside and out and found nothing and nothing in the filter housing. my thoughts are
truck sits alot and possibly since the crank is dry its flaking it off the main bearings?
one diesel tech said my main bearings are blown and everyone else says its fine.
any thoughts? experiences?
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
post #2 of 9 Old 02-28-2012, 12:06 AM
jrholod's Avatar
If they're aluminum, and not copper, it could be a sign of your low-pressure oil pump going.
I had this happen - a lifter broke apart and sent some pins throught the pump and eroded away the aluminum cover of the pump, sending aluminum shavings straight to the first stop - the oil filter housing. Eventually (like, very quickly actually) the pump stopped working altogether. I'm just glad I caught it before my camshaft got fried...
Best of luck.
jrholod is offline
post #3 of 9 Old 02-28-2012, 01:29 AM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
theres many parts that can do something like that. however over a year ago, my hpop gernaded on a 2k mi round trip half way into it. swapped it out and got to the destination, changed oil and saw the copper flakes to in the oil. that happend to go through injectors too.
so do a blackstone oil test asap on the next oil change and send it off.
2006 Ford F250 CCSB FX4 6.0
Sold
1997 F350 CCLB 2WD 7.3
1999 F350 CCLB 4WD 7.3
2003 F350 CCLB FX4 6.0
LSP Chapter Director
LSP Group Threads
Jarrod B is offline
post #4 of 9 Old 02-28-2012, 02:00 AM
usnavyad's Avatar
Feedback Score: 3 reviews
Id say bearings also if its copper to my knowledge there isnt much copper inside lol
04 harley davidson f-250 arp headstuds oem gaskets,sb intake,edge cts egt probe,sct sf3 idp tuned/ php tuned,blue spring,zerex coolant swap,mbrp 5 inch xdp 6 inch tip,sinister egr cooler,new oem oil cooler,atlas 40 ficm,Painted cac tubes 7.3l wire loom,Diesel site coolant filter
GPDA's other shawn
usnavyad is offline
post #5 of 9 Old 02-28-2012, 09:45 AM
ebusa's Avatar
babbit --> lmao
-Evan
Semper Fi
2005 F350 Crew Cab LB FX4 Lariat
Loaded-Leather, Sunroof, 06 Chrome Package
5'' Tuff Country Lift
Toyo MT's 35's with Race Line Renegade 20's
ARP Studs, EGR Cooler Delete, Coolant Filter
MBRP 4'' Exhaust Turbo back, No Cat
SCT X3 Tuned by TSD & IDP
Stock Airbox, NON-MAF Truck
GT3788VA POWERMAX Turbo
DiProcol Optix EGT & Boost Guages , Scangauge II
ebusa is offline
post #6 of 9 Old 02-28-2012, 11:24 AM
Sinister Diesel Sucks!!!
michaelaiman's Avatar
Quoted: 275 Post(s)
Maybe get a real oil pressure gauge, the dummy gauge is just a switch that proves theres at least 7 psi. W/ a real gauge you can get a better idea of where your mains may stand. My experience has shown bad mains will cause low oil pressure readings, especially at idle.
03 F350 SD 6.0 PSD FX4 XLT CC LB SRW FOR SALE!!
To see why you should avoid Sinister Diesel, visit these threads:
michaelaiman is offline
post #7 of 9 Old 02-28-2012, 08:06 PM Thread Starter
ODAWG714's Avatar
Quoted: 6 Post(s)
im thinking since i barely drive it the main get dry or not as lubed as a daily driver and its just excess that flakes off. they are very minor and do not make it to my filter. ill send a sample anyway. im certain the flakes are copper, a ford master mechanic said my main was blown lol but yet theres no actual negative signs of a blown main and the oil filter housing is clean. the mord master mechanic says its a mystery lmao
Oliver
ODAWG714 is offline
post #8 of 9 Old 02-28-2012, 08:16 PM Thread Starter
ODAWG714's Avatar
Quoted: 6 Post(s)
it may also be from my drain plug, the brass copper whatever ring maybe flaking and the oil pushes it into the funnel?
Oliver
ODAWG714 is offline
post #9 of 9 Old 02-29-2012, 11:32 AM
Quoted: 275 Post(s)
Mine is not a daily driver. maybe once a week, sometimes once every 2, and ive never seen any flakes, and Im always checkin to make sure there is none.
