miss on cylinder 4.. now what?? - Ford Powerstroke Diesel Forum
Old 02-27-2012, 04:21 PM
just got done doing an egr delete and head studs,, finally got the truck fired up tonight and its idling rough and keeps showing code p0272 ( little/no contribution from cylinder 4). is there a way to check if the injector/harness is getting power, or did i bend a push rod??
Old 02-27-2012, 05:43 PM
Powerstroke Techie
Feedback Score: 3 reviews
check your injector connector first at the rocker box then I'd be looking at those pushrods
Old 03-10-2012, 04:10 PM
Had same problem with mine. WDS showed #4 not contributing, took off valve cover, found exhaust rocker busted for #2 cyl.
