Originally Posted by livinglegend18
lately i been noticing when im on the highway im getting a vibration at 70mph this is only at 70 after that it runs fine idk what it could be?
is it a 4x4 and if it is do you have manual or autohubs? If you have auto hubs could be your front drive shaft. Check it for play or balance. i know my front velocity joint is shot, but I have manual hubs so only does it when I engage the 4x4 ! Hope it helps. also check your wheel balance even tho usually out of balance happens 54-70 mph. You might want to consider checking your wheel bearings and worse case you rotors might be warped. All I can think of.
