White smoke no power
05 f250 6.0, it was driving fine then all of a sudden i lost all power and pouring white smoke, no engine lights and all gauges are normal
Remove you intake tube and check to make sure your compressor wheel is still spinning. Do you still show boost? If not I would suspect you lost the hot side of the turbo wheel and it stuck in the downpipe and the white smoke coming from the burning oil.
YIKES !!,that could be alotta' chit !! did she overheat,and do you smell coolant/antifreeze ?
Ok so its the egr and oil cooler. What is the best EGR delete kit and is there anything else that i should do once im in there, someone told me to check the O O ring on the HPOP
as long as the intake manifold is coming off pull the hpop cover and replace the STC fitting if it hasn't been changed yet.
The part number for the new one piece connector is 4C3Z-9B246-F |
I know of 4-5 trucks running the dicad solutions kit including my own,,and no problems so far,,$150
