Did I fry my FICM - Ford Powerstroke Diesel Forum
Old 02-22-2012, 03:48 PM
Did I fry my FICM
my FICM has been giving me some issues lately. Sometimes the truck doesn`t want to start but I find if I plug it in and wait 15min it will start. Today I did not plug it in at work and when I went out after work the truck would turn over but not fully start up. I plugged it in. When I went to try the truck seemed to start up but then quickly died. Now the truck is completely dead. I have accessory and everything but when I turn to the key to start the truck it is completely dead. Absolutely no response. I tried boosting it to no avail. I put a new starter on the truck like 2 months ago. So I dont think it is that. I think I just fried my FICM. Any other input would be great. Thank you.
Old 02-22-2012, 04:56 PM
First off the FICM has nuthing to do with the starter working, it only controls injection.
You may ahve a bad starter solenoid, a issue with the ignition key or module or something as the starter fuze or relay blowing even the ignition relay.
Old 02-23-2012, 02:41 AM
Yeah I will check the fuses today. It could be something as simple as that.
Old 02-23-2012, 06:52 AM
Ive ran into instances where the wiring harness was bad and the truck wouldnt crank either. Grabbed the wiring harness and pulled and wiggled on it and the truck fired up. Something easy to check.
Old 02-23-2012, 01:43 PM
I have a brand new ford starter,that I now and then have to tap with a hammer to start working.
Old 02-24-2012, 07:03 PM
I got the truck towed home so I will try too mess around with it and see what is going on. My starter is still under warranty so I just see what happens
Old 02-26-2012, 04:20 AM
i i bought anew ficm it did just that turn key nothing put old one back on it crank but no start??called jim true ford nice guy but truck had to go into be programed with new ficm then it worked i was sure buy new one put it on would work no had to go in anyway
