6.0 oil running a little warm..need help - Ford Powerstroke Diesel Forum
Old 02-21-2012, 07:21 PM
I have some oil cooler questions. I have a 2005 F-350 crew cab with an SCT programmer, Edge insight screen,EGR Delete, fuel spring update, 4" inch turbo back exhaust. I recently drove my truck to colorado from Iowa pulling a 24' enclosed trailer and my oil temperature was averaging 220-233..i'd hit the higher temp on the real steep grades..my coolant temp was anywhere from 180 to 201, but as soon as i'd unhook the trailer the temp would drop to 178 for coolant and around 200 for oil..which is what it normally runs at..what is too hot for the oil temp? How hard is the oil cooler to change or is there any other options to get that oil temp down?
Old 02-21-2012, 07:27 PM
thats getting warm. how heavy was the trailer? what do your ect vs eot run with no trailer?
heres my oil cooler write up to.
http://powerstrokenation.com/forums/...188&highlight=
Old 02-21-2012, 07:49 PM
I think the trailer weighed about 2400 empty..and when im running my truck with no trailer unloaded my EGT's run anywhere from 500-700 depending on how fast im going..and my oil temp never usually gets over 200 and my coolant usually stays below 180
Old 02-21-2012, 07:58 PM
I'm doing my oil cooler right now. My oil temps on mine I've seen as high as 240 degrees towing a car and dolly. Without a load on my engine my oil cooler will run about 210 degrees. I got this Superchips 1855 tuner about 2 months ago, and it give me an option to monitor various different things on my vehicle. This is how I found out my oil cooler was plugged. I've never seen my engine run more than 183 degrees on my scan guage. Sounds like your going to need a cooler in the future. The only major PIA thing when doing the oil cooler is removing the turbo. Make sure you do an EGR Delete if you haven't done one yet.
Old 02-22-2012, 07:05 PM
Yep your oil cooler is toast. My truck runs ect188 and oil temp never goes over 190. Unless towing. That's how it should be.
Old 02-23-2012, 09:57 PM
What should I replace my cooler with? A factory one or is there an upgraded one that flows and cools better? I was also thinking about going with a coolant filter system
Tags
2005 f350 king ranch
