Oil leak help - Ford Powerstroke Diesel Forum
Old 02-21-2012, 08:20 AM
Oil leak help
So last night I was underneath my truck making sure the power wire to my backup lights didn't come loose, and I found a little oil leak. I havn't seen any on the ground so I don't think its real bad but I still don't like leaks. Any ideas on where its coming from? This is on the drivers side exhaust manifold.
Old 02-21-2012, 08:21 AM
Carbon huffing animal
dude, that is one small pic....
Old 02-21-2012, 08:53 AM
This could be from your IPR valve or the HPOP cover. If it is not running down from above the exhaust manifold I would suspect a over fueling injector. Does your truck smoke?
Old 02-21-2012, 09:49 AM
It looks to me like it is coming from somewhere up above the manifold. And no it doesn't smoke. Where is the IPR valve located?
Old 02-22-2012, 07:51 AM
anyone know?
Old 02-22-2012, 07:56 AM
IPR valve is in the HPOP back below/under the turbo. That and check the valve cover/ccv hose that goes into the intake tube.
