another blue smoke problem post
hello wondering if u guys could help me my truck blows small amount of blue smoke at idle are taking off at a stop sing only when warm and smells like unburn deisal. not sure if it is a injector the turbo seal or head gasket any input would help. truck has head studs, edge tuner, 5 inch stright pipe cold air intake thank you
Subscribed....
bump any one need help
It could be a turbo oil seal leaking. a oil ring on a piston or just oil being drawn thru the intake side of the turbo from a saturated ccv filter, or even a injector over fueling a little.
yea but how do i check the injectors to see what one is bad and how to check any of the other ones
anyone know how to check the injectors
I think of short of pulling them and having em bench tested, the only other way is a cyclinder balance test which takes plugging into capable equipment. Even wth that, i think it would be tough to say wether its an injector, or rings etc.
ok thanks i have a scanner but that doesn't check the injectors right. newer to diesels so don't know much. i looked at my turbo earlier and saw oil on the turbo by that plug that go s into the turbo does that mean the seals are bad or the oil line just leaking
to anyone having this problem check your turbo seals
Has your engine ever been apart? For head gaskets or somethin? I think a bent push rod could be one possible cause of your blue smoke/unburned diesel smell
