New water pump and fan doesn't disengage???? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-19-2012, 12:36 PM Thread Starter
Location: Greencastle, PA/ Marine Barracks Washington D. C.
My water pump just took a crap. I replaced it today and now the fan clutch doesn't disengage. Ive driven it to operating temp and let it cool back down and still stays engaged. I am sure I put everything back on correct and put in brand new coolant that was 50/50 already...
2003 F-250 6.0
-6spd 4X4
-aFe Stage 2 intake
-aFe intake manifold
-Zoodad
-4" MBRP turbo back duals 6X24 tips
-ARP head studs
-Custom tuned SCT
-EGR cooler upgrade
-Oil cooler upgrade
-Custom removed blow by pipe
-2.5 leveling kit
StrokenUSMC03 is offline
post #2 of 11 Old 02-19-2012, 12:44 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Why do you say it stays engaged? The fan will turn just from the slippage in between the clutches, just not at full speed when the clutch is engaged. When engaged, you WILL hear it roaring when driving.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 11 Old 02-19-2012, 06:55 PM Thread Starter
Ok... well it roars. I.E. it stays engaged as in when the RPM's rev up fast the noise of the fan being engaged increases. When I down shift from a higher gear to a lower gear you can hear the fan roar up.
2003 F-250 6.0
-6spd 4X4
-aFe Stage 2 intake
-Zoodad
-ARP head studs
-Custom tuned SCT
-EGR cooler upgrade
-Oil cooler upgrade
-2.5 leveling kit
post #4 of 11 Old 02-19-2012, 06:59 PM
Fantom's Avatar
Quoted: 12 Post(s)
Feedback Score: 4 reviews
What symptoms were you seeing to diagnose the bad water pump?
John
2004 Harley Davidson F250 #1191 - 6.0 Powerstroke
Studded - Lots Of Bulletproof Diesel Parts
Swamps 58v FICM - KC Stage 2 Turbo
Ported Intake - S&B CAI
100,000 Miles
Live in Northern California? Stop in here and say hi
Fantom is offline
post #5 of 11 Old 02-19-2012, 07:09 PM Thread Starter
Engine water temp gauge around 3/4 and stopped and walked in front of my truck and saw coolant pouring down like a water fall. Then when I tore it apart and looked at the water pump you could see the stain where the coolant was leaking out.
2003 F-250 6.0
-6spd 4X4
-aFe Stage 2 intake
-Zoodad
-ARP head studs
-Custom tuned SCT
-EGR cooler upgrade
-Oil cooler upgrade
-2.5 leveling kit
post #6 of 11 Old 02-19-2012, 07:14 PM
Fantom's Avatar
Quoted: 12 Post(s)
Yeah, that's a pretty good symptom.
John
100,000 Miles
Fantom is offline
post #7 of 11 Old 02-19-2012, 07:16 PM Thread Starter
Yeah I have 150,000+ on the truck so I figured it was only a matter of time really until it went. What I am trying to figure out is why the fan clutch doesn't disengage.
2003 F-250 6.0
-6spd 4X4
-aFe Stage 2 intake
-Zoodad
-ARP head studs
-Custom tuned SCT
-EGR cooler upgrade
-Oil cooler upgrade
-2.5 leveling kit
post #8 of 11 Old 02-20-2012, 07:07 AM
Powerstroke Techie
m-chan68's Avatar
Quoted: 3 Post(s)
Do you have a way to verify actual coolant temperature other than the idiot gauge on the instrument cluster? By the way, if it got as hot as you've described, hopefully you didn't do other damage. Where exactly did you see coolant pouring out? Those 2003 model year water pumps were pretty well known for reliability issues.
Ford Diesel/Senior/Master Tech who placed 2nd overall in Ontario on the Fix-It-Right-First-Visit score for 2010
....who works at a dealership that now employs SOME half decent looking female employees since they overhauled most of the administrative staff
....but STILL loves hot women with big boobies
....and STILL hates working on E-Series with 6.0L
m-chan68 is offline
post #9 of 11 Old 04-26-2012, 07:36 PM
Heres what I am dealing with. Again with the early 6.0! I was told by a dealer that my hgs are blown. The only problem I am having with the truck is the fan clutch is kicking on and off for no reason. At highway speeds the temp gauge goes fairly high then comes back down. No loss of power, no puking, no coolant loss and no white smoke or any smoke from the tailpipe. I changed the fan clutch thinking it was bad like it has before. I replaced the ect sensor. It did not help. I replaced the oil cooler and did the egr delete myself about 20K miles ago. Been running good. Just about had with the old beech. Anyone have any suggestions? How about a good independent mechanic in Dallas?
memarkers is offline
post #10 of 11 Old 04-26-2012, 09:58 PM
I am just not shure what the question or the problem is here. I see being described is the normal operation of a clutch fan and a engine cooling system.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
