A/c heater only blowing through defroster vents - Ford Powerstroke Diesel Forum
Old 02-18-2012, 03:12 PM
I had some work done on the high pressure oil pump, and now I get hot air in the cab. when I turn on the A/C it blow through the defroster. No matter were I try and send the air it goes to defroster. The vac continues to run all the time. I disconnected something that in bolted to the right fender by the vac pump and a black box now the vac will stop and I can change to all vents. I tried to change that part on a friend truck that his work just fine and it went back to doing the same thing. If I unplug it all works fine. any help with this problem Thank you!
Old 02-18-2012, 05:25 PM
i did the same work on my oil pump and now my air comes thru the defrost to
Old 02-20-2012, 07:29 AM
there is a vaccuum line unplugged somewhere. the vaccuum pump on the fender shouldnt run all the time. If the pump goes bad or a line comes off the default is blowing air through the defroster.
Old 02-20-2012, 03:23 PM
I found the problem after looking at some other forums on the net. The Vac. hose had came off on the front left hub. Thanks for your input!
