Dirty turbo pics - Ford Powerstroke Diesel Forum
post #1 of 9 Old 02-18-2012, 02:13 PM Thread Starter
06kngrnch84's Avatar
Dirty turbo pics
Ok so I just cleaned this thing a month ago, probably about 1000 miles, started having some surging issues this week. I'm out tryin to figure out what's goin on. I took off my EBP sensor and it was nasty, cleaned that. Decided to go ahead and pull my turbo and check it out, since I've become a pro at this in the past couple months, lol! Anyway this is what I found, its filthy again. Completely dusted with carbon buildup. What is causing it to get so dirty so fast? Any input is appreciated. Thanks
Sent from my HERO200 using AutoGuide.Com Free
ID:	34081   Click image for larger version
Jackson, MS. 2006 Ford F-350 SRW King Ranch FX4 Crew Cab, All Stock, 160,000 miles
EGR Delete
Updated HPOP Fitting
Updated Standpipes and Dummy Plugs
ELC Coolant
Coolant Filter
Scan Gauge II
New Oil Cooler
Blue Spring Kit
'04 Metal Cold Side CAC Tube
06kngrnch84 is offline
post #2 of 9 Old 02-18-2012, 02:20 PM
Has the truck been smokeing a lot?
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #3 of 9 Old 02-18-2012, 02:26 PM Thread Starter
No, I haven't seen the first puff of smoke since I did my egr delete, about a month ago, same time I cleaned the turbo
EGR Delete
ELC Coolant
Coolant Filter
Scan Gauge II
New Oil Cooler
Blue Spring Kit
post #4 of 9 Old 02-18-2012, 02:29 PM
when ya did the egr was the intake oily may need to boil it and check the cvc canister
post #5 of 9 Old 02-18-2012, 02:39 PM Thread Starter
I took the intake completely off and cleaned it, and I also plan on doing the ccv mod this weekend, could this be the problem? But the intake tube from the air filter was slightly oily. It was pretty clean and dry today, and only a small drop of oil on the intake side of the turbo. The most oil pooling that I seen today was on the lower boot of the passenger side Cac tube
EGR Delete
ELC Coolant
Coolant Filter
Scan Gauge II
New Oil Cooler
Blue Spring Kit
post #6 of 9 Old 02-18-2012, 05:50 PM
Powerstroke Techie
Quoted: 17 Post(s)
Garage
Feedback Score: 4 reviews
the surging issue may or may not even be related to the movement inside the turbo. does the unison ring rotate freely on the center housing? do the vanes pivot freely with the ring on them?
the turbo is going to get carbon on inside within the first couple hundred miles of driving, that's not what inhibits movement, wear on the metal parts and rust are the problems.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #7 of 9 Old 02-18-2012, 06:17 PM Thread Starter
I know this may not be the source of the surging, just figured I would check it while it was the weekend and I had time, to rule it out. Yes everything moves freely, and I don't see any signs of rusting or pitting. I mean I didn't expect it to stay all clean and shiny, just thought this may have been a little excessive buildup for only 1000 miles.
EGR Delete
ELC Coolant
Coolant Filter
Scan Gauge II
New Oil Cooler
Blue Spring Kit
post #8 of 9 Old 02-18-2012, 06:24 PM
xpbprox's Avatar
Did you put some anti-sieze in there?
04 F-350 XLT FX4 CC LB SRW leveled, SCT w/ innovative tunes, Edge Insight gauges, Str8 pipe, Studs, Bulletproof EGR, valve seats, 6.4 banjo bolts, updated fuel pressure spring
89 F-350 Centurion Lariat 4X4 CC BB STW lifted on 35"s
460 E4OD
6.0 BIBLE
xpbprox is offline
post #9 of 9 Old 02-18-2012, 06:32 PM Thread Starter
Yes, a very light coat
EGR Delete
ELC Coolant
Coolant Filter
Scan Gauge II
New Oil Cooler
Blue Spring Kit
