codes after egr delete and oil cooler replacement - Ford Powerstroke Diesel Forum
Old 02-17-2012, 05:22 PM
Hey guys i have a 2004 (early 04 so 03 motor.) f350 6.0 and i just had the egr delete done and oil cooler replaced as it was apart. I bought brand new and after i got the truck back from the shop the check engine light came on and my edge insight cs came up with a p006a code mass volume correlation ? and a p132B something to do with the turbo? what are these codes exactly and what can be done. The shop now wants to charge me 80 bucks to diag the truck and see whats wrong with it. The check engine light didnt stay on long i earsed the code and it did end up comming back on how ever it did go out and it hasnt been on since and i drove the truck about 80 miles so far after it went out. ALSO my full throttle boost is only 19 psi? Stock no tune stock tire size and only thing aftermarket is 4 in turbo back exhaust.
Old 02-19-2012, 04:54 PM
can anyone help me?
Old 02-20-2012, 12:20 PM
I would check all the connections to the wiring sensors and look for an exhaust or intercooler pipe leak. Especially take a look at the VGT wire on the turbo and make sure it is tight and not melted to the housing
Old 02-21-2012, 06:14 AM
Do you have any whistles or air surging noises when WOT? As Terra stated check all your connections. I have seen guys mess up intake gaskets that will cause lack of boost. Torn CAC boots will also cause this issue. Just do a quick overlook under the hood, and see if you see anything major, also do it running and see if you can smell exhaust under the hood.
Old 05-20-2012, 08:48 AM
Did you ever find the fix for this? I'm getting the same codes after doing an EGR delete and oil cooler replacement. Everything worked just fine when I first did all the work. Drove from Anchorage, AK and made it to Seattle with no issues. Then all of a sudden I had a lack of power from the turbo and the same codes.
Old 05-20-2012, 09:52 AM
^^what year is your truck?
does it have a tuner?
what are the exact codes?
a correlation code means that the pcm is not seeing values it expects from either the MAP, BARO, or EBP.. IIRC
