Head gaskets and studs....replace intake and exhaust gaskets too???? - Ford Powerstroke Diesel Forum
Old 02-16-2012, 11:54 AM
what is the min. gaskets for a head job on the 6.0 just the head gaskets or do you have to get the exhaust and intake gaskets too? already have the heads to come off. I am not messing with injectors or gp either.
Old 02-16-2012, 12:55 PM
The odds of getting the exhaust gaskets off clean are slim and if your haveing the heads checked the machine shop will want them off. Not haveing the heads checked is asking for trouble.
The intake gaskets are reuseable altho if they look questionable I would replace them.
Be shure and replace the copper gaskets on all fuel lines.
Old 02-16-2012, 08:25 PM
you will have to pull the injectors , and when you do that you need to replace the injector seals. While you ar ein there, do the standpipes nd dummy plugs.
MikeB
Old 02-17-2012, 02:40 AM
Why is it required to mess with the injectors? I am working on the truck for a friend and he is selling it as soon as it is fixed. So he is trying to get out as inexpensive as possible.
Old 02-17-2012, 04:59 AM
Send a message via AIM to jimmyv13 Send a message via Yahoo to jimmyv13
The injectors are installed into the heads and need to be pulled to remove the heads from the block.
Old 03-14-2012, 12:03 AM
do the front engine gasket wile your in there ! couldnt hurt.
