Cracked Head..Need advice - Ford Powerstroke Diesel Forum
post #1 of 16 Old 02-15-2012, 06:21 AM Thread Starter
I have a 2005 F250 6.0L and recently found out that the passenger side head was cracked. I am trying to figure out the cheapest way to go on it. My options are replacing the head but the mechanic that looked at it said there's a really good chance of more parts being damaged, replacing the engine, or selling the truck as is. I have no idea what it is worth with a cracked head if someone could give me an idea that would help me out a lot. Just looking for any advice anyone can give me on this. Thanks.
alabenz9 is offline
post #2 of 16 Old 02-15-2012, 06:40 AM
Quoted: 5 Post(s)
So why are the heads off? If the head is cracked most of the time they can be repaired. If the cracks in the head are just the exhaust valve seats then the seats can be replaced. What other damage could be done??
05 Extended Cab FX4
SCT w/ Gearhead Tunes
Ble-Blah mod...
Edge Insight CTS w/EGT
PHP Tuned FICM-Hercules
a2elvis is online now
post #3 of 16 Old 02-15-2012, 06:46 AM Thread Starter
The heads arent off. It was leaking a lot of oil when I woke up one morning and wasn't starting so had it towed to a mechanic to take a look at it and he call and said it was cracked and wouldn't know if anything else was damaged or not until he got in and took the heads off.
alabenz9 is offline
post #4 of 16 Old 02-15-2012, 07:09 AM
badyota82's Avatar
Was it cranking ok? Sounds like a mechanic may be trying to take advantage of you. I would first suspect high pressure oil leak, whether internal, or external. If injectors can't get high pres oil, your truck will never start.
Do you have a way to monitor icp duty cycles and pressures?
2006 F250 Lariat FX4:
MBRP 4" Turbo Back Exhaust
Blue FPR Spring
Edge Insight CTS
1200rpm High Idle Mod
Dieselsite Coolant Filter
58v Swamps FICM
SCT w/ Matt's SRL Tune
6.4 Banjo Bolts
CCV Mod
2006 F250 Lariat CC FX4
Current Mods:
4" MBRP Exhaust
58v FICM w/ performance flash
Blue FPR Spring
SCT w/ tunes from Matt (SRL, 8k Tow, Unlim. Tow)
Edge Insight CTS
1200rpm High Idle
Coolant Filtration System
6.4 Banjo Bolts
ARP Head Studs
EGR Delete
Sold: 1997 F250 PSD 4x2 5 speed
badyota82 is offline
post #5 of 16 Old 02-15-2012, 07:14 AM Thread Starter
yea it sounded like it was cranking fine just not starting up. at first when i talked to him over the phone he thought it might be the IPR valve. My first thought was High Pressure Oil Pump. This is the first time I've taken it to this mechanic I usually use a different guy but he was one of my buddies friends and closer so I thought I'd save money on the tow.
alabenz9 is offline
post #6 of 16 Old 02-15-2012, 07:35 AM
LNS4x4's Avatar
Not all mechanics are the same, you should really take it to someone who knows how to work on powerstrokes/diesels.
2005 6.0 PSD XLT SD FX4 CC LB
Engine:
SCT, SRL, Atlas 80, Arp's, Bulletproof Oil cooler w/ Cold weather package, All aluminum radiator, Bulletproof water pump, Sinister Full Delete, 4" Mbrp turbo-back, Banks Techni-Cooler, Banks intake, Edge insight CTS, Diesel site coolant filtration, CCV Mod.
Suspension:
2.5 Icon Leveling kit, 5" Icon rear block, Pure Performance adjustable trackbar, King shocks, PMF 3 link.
LNS4x4 is offline
post #7 of 16 Old 02-15-2012, 07:38 AM Thread Starter
both of the guys that I've taken it to do specialize in powerstrokes.
alabenz9 is offline
post #8 of 16 Old 02-15-2012, 10:12 AM
Quoted: 5 Post(s)
K well a cracked head is not going to cause a no start. So what sounds like may have happened is that the STC fitting on the HPOP has failed and blown apart. When this happens it can cause a no start as well as an oil leak. The reason it causes a oil leak is because it blows apart with such force that it blows a hole in the rear cover.
05 Extended Cab FX4
Ble-Blah mod...
post #9 of 16 Old 02-15-2012, 10:20 AM Thread Starter
Yea it could be that I was just told that a head was cracked so I thought I would see others opinions since it kind of put me in a tight spot.
alabenz9 is offline
post #10 of 16 Old 02-15-2012, 10:24 AM
Quoted: 5 Post(s)
Well like I said a "cracked head" is not going to cause a no start. So sounds to me like you need to have the truck taken somewhere else.
05 Extended Cab FX4
Ble-Blah mod...
