loss of power and shacking - Ford Powerstroke Diesel Forum
post #1 of 3 Old 02-13-2012, 05:00 PM Thread Starter
Exclamation loss of power and shacking
my 07 6.0l had a bad injector in it and didnt pull any codes but put it on a scanner and found it so i put a new 1 in it and was sacking bad after and found it was a ujoint.fixed that and run good now on the way home the truck started to act like it did with the bad injector again then completely lost all power and shacking it is now pulling codes p0266 p0272 p0281 with say they are contribution/balance Power cylinder, valve train or injector what does that mean? and code p0299 and p0404 i know what they are but dont know what they mean aswell. could it all be from another bad injector going dead or is the new 1 effecting the other by being stronger then the others
tutuffcustoms is offline
post #2 of 3 Old 02-13-2012, 06:51 PM
southend's Avatar
if it helps mine was vibrating around 60-70, found it to be a bad #4 injector got a P0270 and P0272, i havent fixed it yet. saving up. you should check your fuel pressure also. check the tech files. BTW rev-x and T6 oil change didnt help either.
southend is offline
post #3 of 3 Old 02-14-2012, 05:04 AM
cajunpsd's Avatar
Rev-x cured the same problem you are having. Had two injectors failing. Keeping my fingers crossed!!!
2007 F-250 King Ranch SD SWB 4x4....
155,000 miles
Edge CS..turbo timer..EGT..FP
Looney Wild tune dd
EGR Delete
New Ford updated oil cooler
New Ford HG's
ARP's
New ICP
Leveling kit
35" Mt's
4" MBRP Alum. tb exhaust
PMM coolant filter
cajunpsd is offline
