Is this something I should be concerned about? - Ford Powerstroke Diesel Forum
Old 02-13-2012, 10:34 AM
Just as the title states, I was under my truck today looking at the location where I'm going to install new EGT probe on exhaust manifold and noticed some wetness in these two spots. I think one is where the tranny meets the motor and the other is simply the oil drain plug. I was able to tighten plug just a tiny bit so maybe that will help, but should I be concerned about these two spots where it appears fluid may be starting to leak? There were no puddles under truck whatsoever, just wetness in these areas on the actual truck itself. Any and all help would be greatly appreciated. Thanks
Is this something I should be concerned about?-img_0429.jpg   Is this something I should be concerned about?-img_0430.jpg
Old 02-13-2012, 02:57 PM
anyone? the first pic which I'm most concerned about is looking up at the front of transmission rear of engine oil pan. Trying to figure out what this could be and if I should be concerned or not
Old 02-13-2012, 03:35 PM
I am not an expert but it could be the Rear Main Seal
Old 02-13-2012, 04:01 PM
If it is, and it's not dripping leaking, is it something I can just keep an eye and not worry about repairing right away? Like I said before, it must be a small leak, cause I've had no puddles only wetness on trans housing
Old 02-13-2012, 04:05 PM
It just looks like the rear main. Can be anything in the motor valley too. HPOP fittings are right above that.
Other one just LOOKS like the drain plug. New gasket next time around, good to go.
Old 02-13-2012, 04:27 PM
If it is rear main, is this something I can live with for now?
Old 02-13-2012, 05:33 PM
I doubt it's the rear. But if it is, if you can live with it making a mess, leave it. If you can deal with puddles, leave it. If you're anal and have to have NO leaks, fix it. But as long as it's not impeding performance, it's like any other leak: it's no necessary to fix.
Old 02-13-2012, 09:29 PM
Looks like mine......as far as I'm concerned: no puddles, no problems.
Old 02-14-2012, 06:11 AM
Glow Plugs Only
Wipe everything down really good and keep an eye as to where it's coming from. Go from there. Follow it all the way back from end to start to pinpoint the trail.
Old 02-14-2012, 07:55 AM
Mine looks the same, was kinda pissed off when I first got it I checked and it was clean under there. Then after driving for a month it looks like the pictures posted above. That's why they call them 6 leakers
