Blowing blue:(( - Ford Powerstroke Diesel Forum
Old 02-13-2012, 06:04 AM
Blowing blue:((
I got an 04.5, been runnin the xcal2 on it with a buddy's tune ( wasn't made for my truck but it does work on it, but it's made for bigger injectors) its been on here about 6 months now, but when it's cold it starts up like crap, so this morning I took it off to see if it would start better, no difference, still crappy.. I got on the highway going 75, and when I let off the pedal a little it would blow blue smoke and start popping and it's giving me #4,6, and 7 injector codes.. I checked my my ficm power and it's putting out 43v, and ipr is right there with desired.. But since this tune was made for bigger injectors, could it be starting to burn my stock ones up?
Old 02-13-2012, 06:14 AM
Put the module back on, ran a self test, buzz test and everything seems to be fine, headed back down the highway and it's fine.. Why would it not like being stock?
Old 02-13-2012, 06:30 AM
43v means your FICM is bad
Old 02-13-2012, 06:57 AM
I put a new oil cooler on a excursion last night and it was at 38 and still running, but why is it running bad stock but not with the Sct
Old 02-13-2012, 07:02 AM
Just checked it again with the Sct on and it's 48v
Old 02-13-2012, 03:23 PM
Powerstroke Techie
Feedback Score: 3 reviews
you probably need a few injectors, it's not unheard of
Old 02-14-2012, 05:19 AM
That's what I was afraid of.. That or a ficm
Old 02-19-2012, 08:34 AM
The tune is making the ficm work harder and it just isn't up to the task... Anything less than 45v is a bad ficm which can cause injector codes and eventually failed injectors... Check your batteries, get your ficm rebuilt, and then worry about injectors if there are still issues.
