degas drip!! - Ford Powerstroke Diesel Forum
Old 02-12-2012, 11:13 AM
degas drip!!
today i noticed a couple drops around my degas cap... it wasnt a puke it was only a couple drops... should i be concerned? it doesnt have any other symptoms... and also, if i drive it and let it sit for about 1/2hr, should there be pressure when i open the cap... not alot, wount blow the cap off or nothing....but pressure does release....
Old 02-12-2012, 03:42 PM
Mine is doing the exact same thing,you need to pressure test at degas bottle....there are alot of threads on hear clearly defining how to do that.Mine only leaks a bit if i hit on the gas hard,if i drive it lightly on hiway theres no leaking....i did a pressure test last sunday,at wide open throttle i reached 19 PSi,in other words,head gaskets are screwed!!!Sounds like your at the same stage i am bud!!
