Running hot after having injector replaced - Ford Powerstroke Diesel Forum
Old 02-10-2012, 05:45 PM
I had 2 of my injectors replaced and I did t even make it to the house and it started running hot. Mec said my water pump was bad but. So I replaced the thormostat and that didn't fix it so then I pulled the radiator out and cleaned it out with aluma bright and cleaned mud off the out side. Now the truck runs normal at night time when it's colder but during the day the temp goes up to about 3/4 the way up but then cools back down. And my heater comes and goes it doesn't blow hot constantly. Please help me I'm ballin on a budget
Old 02-10-2012, 05:57 PM
How much coolant is in the de gas bottle ?
sent from ^^^ his phone with jedi mind tricks
Old 02-10-2012, 06:11 PM
What is the de gas bottle?
Old 02-10-2012, 06:39 PM
Send a message via AIM to CTC DEEZUL
the tank or overflow... was the system filled with an Airlift or equivalent vacuum type
Old 02-11-2012, 08:47 AM
I didn't use a vacuume I just pored it in there
Old 02-11-2012, 09:03 AM
Might be your issue. Air pocket
Old 02-11-2012, 10:49 AM
Ok I'll try that. Thanks man
Old 02-11-2012, 07:59 PM
Since you had 2 injectors replaced there is a possibility that one or both injectoor tubes was unseated and is allowing combustion gases into the collant system. Rare but does happen.
