Another botched EGR Delete! - Ford Powerstroke Diesel Forum
Old 02-10-2012, 04:53 PM
Just finished my egr delete, got the turbo set so the gap between the y pipe is non existent on one side and microscopic on the other. Tightened everything up and can hear a very faint but obvious exhaust leak. I have felt around all of the connections and cant feel a whisper of exhaust. I let it warm up and drove it around the block, it has very low boost. The stock egr valve is in place and I have no CEL. Im going to go back out and check all of the piping to the intercooler, but beyond that I am completely lost as to what to do next, any help would be greatly appreciated.
Also, I noticed this little bugger (circled in red) without a connection, but I cant find a missing hose anywhere in the shop or where it would plug in to...? And now I feel kind of like and idiot... Its on the left side of the intake when facing the truck. directly to the left of it is the fill pipe for the engine oil.
[IMG][/IMG]
Old 02-10-2012, 05:24 PM
Send a message via AIM to jimmyv13 Send a message via Yahoo to jimmyv13
Can you had a woooooosh sound when you acellerate?
Old 02-10-2012, 05:35 PM
Powerstroke Techie
You've just answered your own question, so I don't know why you are even bothering to post this. That brass nipple on the intake is where your MAP sensor hose is supposed to connect to, and the direct reason why you have very little to no turbo boost (and likely a P2262 code set if you were to check). The MAP sensor is bolted to a bracket, which is in turn bolted to the evaporator housing on the passenger side of the engine compartment with three 10mm nuts. This sensor has a wiring connector with a red lock tab on it, and a rubber hose with small red squeeze type clamp securing it. The other end of it, is supposed to connect to the brass nipple you circled in your picture.
Old 02-10-2012, 05:37 PM
Nope no wooshing, just a hiss almost like the tv is turned all the way up and the cable goes out when you don't pay the billon time
Old 02-10-2012, 05:39 PM
Powerstroke Techie
And the air exiting the brass nipple is the sound you are hearing when you accelerate.
Old 02-10-2012, 05:44 PM
Send a message via AIM to CTC DEEZUL
yeap... its that black corrugated(black crunch wrap) line thats next to heater hose... it routes under the heater hose... has a red clamp on it...
Old 02-10-2012, 05:51 PM
Is that's what's causing the assumed "exhaust leak" and lack of boost...? This sucker is almost as gutless as when the egr went out to begin with...
Old 02-10-2012, 05:52 PM
yes... just as the guy before me said... go look at it..... its that line I said it was... put it on, clear codes, and beat the brakes off the thing
Old 02-10-2012, 05:58 PM
Ok im sitting on the truck right now, resetting the turbo to the y pipe one more time just to make effin sure I got it right, gonna tighten it up, already attached the hose that my assistant somehow missed, and procede to drive this wagon like I stole it.
Ps. You guys are amazing.
Old 02-10-2012, 06:00 PM
Maybe its because Ive been doing the y-pipe thing for 3 years now... but what is so hard about it???
I have had some that when I took the clamp off, the y shot off and had about an inch gap and Ive still gotten then to seal up without loosening the uppies
